| History of slant six part throttle kick down https://slantsix.org/forum/viewtopic.php?t=64595 |
Page 2 of 3 |
| Author: | SlantSixDan [ Tue Mar 10, 2020 5:48 pm ] |
| Post subject: | Re: History of slant six part throttle kick down |
This really oughtta be in the Transmission section, perhaps as a sticky, no? I'll be interested to see the TSBs as listed on the table of contents page if/when you post them. Meanwhile, '67 wasn't quite the start of part-throttle downshift on Torqueflites; that actually came as a production test run in '66 as documented here. And speaking of TSBs: • Governor noise on '66 904s—I had an original unrebuilt '66 904 in the '90s that worked fine but made this irritating noise. • Increased WOT upshift speeds on 904s and 727s, early '66 • Cushioned clutch for smoother neutral-to-drive engagement on Slant-6 904s, early '66 • Always check to make sure you don't have any screws loose! • Real cold out? Shift your Torqueflite to Neutral before starting the engine… • …unless yours is a Torqueflite made after this round of changes, then go ahead and start in Park. • Looks like a number of small-nose torque converters and associated transmissions escaped their Canadian cage in 1972 (assuming the smaller nose described is the same small nose as the '67-down item). |
| Author: | matv91 [ Tue Mar 10, 2020 6:11 pm ] |
New 2-3 shift valve
| Author: | matv91 [ Tue Mar 10, 2020 6:15 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 6:16 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 6:18 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 6:21 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 6:31 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 6:32 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 7:28 pm ] |
Slant six gets limit valve
| Author: | matv91 [ Tue Mar 10, 2020 7:33 pm ] |
Lower shift limts
| Author: | matv91 [ Tue Mar 10, 2020 7:48 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 7:54 pm ] |
Hydro circuit for both six and v8 1979 fsm
| Author: | matv91 [ Tue Mar 10, 2020 8:02 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 8:09 pm ] |
| Author: | matv91 [ Tue Mar 10, 2020 8:12 pm ] |
| Page 2 of 3 | All times are UTC-08:00 |
