It is currently Tue Oct 13, 2026 10:19 pm
PostPosted: Mon Mar 30, 2020 3:40 pm
If it hasn't been mentioned already, with some of the 5 bolt pumps you have to glue in a small extra piece of gasket material or the oil.pump will not make pressure. I had to do it on my engine. I went from zero to 60 on oil pressure once I added that little piece of gasket. I think it's in one of docs oil pumps. https://www.flickr.com/photos/13718356@ ... 499249739/
PostPosted: Thu Apr 09, 2020 3:40 pm
It should be noted that when I took the oil filter off, there was essentially no oil in it. That clearly is not right.
Not necesarily. You can find a discussion about some filters that have an internal tube, to keep the oil inside the filter at shut off... The early slants had one tube in the filter connection. I don't recall in what thread that info is, but you might have a filter with no oil (when the engine stops...). Hopefully the filter was wet.
UPDATE: Found the discussion thread about the tube:
http://www.slantsix.org/forum/viewtopic ... ilter+tube
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
PostPosted: Thu Sep 10, 2020 10:23 am
Well, it turned out to be the oil pump. It failed. Luckily it didn't damage the cam. I had to have the engine pulled to replace it. Oof. New oil pump installed.
PostPosted: Thu Sep 10, 2020 10:32 am
What kind of filter? How long since last oil change?
Also remember that on these engines, the oil filter hangs "upside down" from how it goes on just about any other engine. Did it all drain out while removing?
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot] and 6 guests
