| Leaf spring, ladder bars, or 4-link? https://slantsix.org/forum/viewtopic.php?t=6478 |
Page 2 of 2 |
| Author: | Uptown Joe [ Sat Aug 16, 2003 2:01 pm ] |
Wishbone or a Triangulated 4 link. You can set up the wishbone or the top bars to be adjustable for pinion angle adjustments. - the rear end locating comes from the triangulation of the top bars or the wishbone (which is just 2 bars that meet before the heim joint instrad of running 2 heim joints on a 4 link) A 4 link is pretty easy to fab. the 2 bottom bars get bushings and the the top bars get bushings on one end, heims on the other. Pick up a copy of Truckin', Street Trucks or even Minitruckin' and there will be a bunch of trucks in there that are running 4 links for pictures. <img src="http://www.trikecreative.com/cicustoms/images/Victims/joe_2.jpg"/> This is a picture of my truck (not a mopar) - the suspension is not done, and it's not a race application, but you get the idea. <img src="http://www.trikecreative.com/cicustoms/images/Dodge_Project/wishbone2.jpg"/> This is a different truck - this one has a wishbone... pretty slick, huh.. Joe |
| Author: | Slant Cecil [ Sun Aug 17, 2003 11:35 pm ] |
The top pic is a copy of the GM coil spring suspension. If the bushings are soft and flexable enough, it won't put the housing in too much of a bind while under travel. OK for street use, not the best for drag use because it hinders housing rotation. The bottom pic looks like a poor design. I don't see a pivot point for the wishbone. If there is, nothing is holding the top of the housing in position. This is a poor design, even for the street. Might work on a show car that doesn't have to function. This does not allow one rear wheel to bump/rebound independantly. The housing can not rotate. There is no way to make a wishbone function as the upper link and give the housing freedom of movement. Cecil |
| Author: | Uptown Joe [ Mon Aug 18, 2003 7:03 am ] |
You should see it throw sides - it has adjustable air suspension with a fill valve and a dump valve at each corner. The truck can lift one corner in the back about 12" by filling the bag on that corner. - I know that you cats are probably not into adjustable suspension... |
| Author: | slantzilla [ Mon Aug 18, 2003 9:43 am ] |
Quote: You should see it throw sides - it has adjustable air suspension with a fill valve and a dump valve at each corner. The truck can lift one corner in the back about 12" by filling the bag on that corner.
- I know that you cats are probably not into adjustable suspension... Yep, not exactly what we are trying to accomplish. Neat pics though. |
| Page 2 of 2 | All times are UTC-07:00 |
