Will slant six 904 bolt to a 360?
https://slantsix.org/forum/viewtopic.php?t=64842
Page 2 of 2
Author:  NEVjr [ Fri May 22, 2020 9:34 pm ]
Post subject:  Re: Will slant six 904 bolt to a 360?
Does your car have disk brakes or drum? What rearend does it have? What size radiator? Do you have a V8 k-member?
looking at a V8 and Slant 6 crossmember from a 64 valiant last year, I couldnt see any differences. the slant mounts would bolt right into the v8 crossmember but for the slightest misalignment. is there a difference? is only some years?
64-66 only used one K-member as far as engine mounting is concerned. You can swap from a Slant to a V-8 by changing motor mounts and brackets (and drag link).
is this true for the 62 as well? i also cant discern any differences between the 64 motor mounts any my 62 motor mounts, but i also havent removed my motor mounts from the car.
Author:  slantzilla [ Fri May 22, 2020 10:22 pm ]
The V-8 was never offered in a '62. I am not sure if the '64 mounts work on the '62 K-frame.
Author:  Joshie225 [ Sat May 23, 2020 10:08 am ]
Wouldn't you also have to change or remove the heater to get a V8 in a '62?
Author:  slantzilla [ Sat May 23, 2020 10:46 am ]
You do have to cut the box or something like that.
Author:  NEVjr [ Sun May 24, 2020 3:01 pm ]
I asked more to satiate my curiosity. its not a swap I am planning. eventually I want to swap in a new pentastar v6
Page 2 of 2 All times are UTC-07:00
