It is currently Tue Nov 17, 2026 3:44 am
PostPosted: Thu Sep 03, 2020 7:29 pm
Vacuum leak somewhere
What’s your theory?
Old mechanics trick use your hand to choke off the air going into the carb if it smooths out it has a vacuum leak the air cleaner has the same effect.
Another old mechanics trick to clear the internal passages: get the engine running at high idle, put your hand over the carb throat briefly, vacuum sucks the passages clear.
PostPosted: Fri Sep 04, 2020 1:16 pm
Car Model: 1966 Dodge Dart 170
You can also try plugging the emulsifier air bleed to see if that changes anything.
This is the small brass port opening you see when looking down the carb.
Use a wire size that mostly fills this hole and secure the other end of the wire to be sure it does not get "sucked-in" when the engine is started.
Thanks, I will try that tomorrow and reply.
No change. Tiny hole.
PostPosted: Sun Sep 20, 2020 6:21 am
Solved! Replaced carb. Now it starts and runs without the air cleaner being in place. I had another carb on a parts car so I took it apart and soaked it in lacquer thinner, ordered a rebuild kit from Mike’s Carburetor, rebuilt it and adjusted it on the bench and “zoom” problem gone.
Thanks for your sharing of ideas. I don’t know what’s wrong with the other carburetor but sounds like it wasn’t cleaned properly by previous rebuilder and something in it is clogged.
PostPosted: Tue Sep 22, 2020 7:29 pm
Car Model: '64 Valiant Convertible
When you tear down the offending carb, it would be great to know what you have found...
Thanks.
