| Engine dies when air cleaner is removed https://slantsix.org/forum/viewtopic.php?t=65276 |
Page 2 of 2 |
| Author: | Reed [ Thu Sep 03, 2020 7:29 pm ] |
| Post subject: | Re: Engine dies when air cleaner is removed |
Quote: Quote: Quote: Vacuum leak somewhere
What’s your theory? |
| Author: | Studebaker [ Fri Sep 04, 2020 1:16 pm ] |
Quote: Quote: You can also try plugging the emulsifier air bleed to see if that changes anything.
Thanks, I will try that tomorrow and reply.This is the small brass port opening you see when looking down the carb. Use a wire size that mostly fills this hole and secure the other end of the wire to be sure it does not get "sucked-in" when the engine is started. DD ![]() |
| Author: | Studebaker [ Sun Sep 20, 2020 6:21 am ] |
Solved! Replaced carb. Now it starts and runs without the air cleaner being in place. I had another carb on a parts car so I took it apart and soaked it in lacquer thinner, ordered a rebuild kit from Mike’s Carburetor, rebuilt it and adjusted it on the bench and “zoom” problem gone. Thanks for your sharing of ideas. I don’t know what’s wrong with the other carburetor but sounds like it wasn’t cleaned properly by previous rebuilder and something in it is clogged. |
| Author: | neilskiw [ Tue Sep 22, 2020 7:29 pm ] |
When you tear down the offending carb, it would be great to know what you have found... Thanks. |
| Page 2 of 2 | All times are UTC-07:00 |
