| Power steering pump alignment https://slantsix.org/forum/viewtopic.php?t=65372 |
Page 2 of 2 |
| Author: | Joshie225 [ Fri Sep 25, 2020 5:56 pm ] |
| Post subject: | Re: Power steering pump alignment |
Quote: There are different PS pump pulley and pump mounting brackets for the AC / PS 225 SL6 vehicles.
Well, I have been giving bad advice. My mistake. The pulley is much "deeper" and the bracket that holds the pump, has a different mounting "off-set". I will see if I can get you a photo... DD |
| Author: | Studebaker [ Fri Sep 25, 2020 6:02 pm ] |
Quote: Quote: There are different PS pump pulley and pump mounting brackets for the AC / PS 225 SL6 vehicles.
Well, I have been giving bad advice. My mistake. The pulley is much "deeper" and the bracket that holds the pump, has a different mounting "off-set". I will see if I can get you a photo... DD Thanks for your efforts. |
| Author: | Studebaker [ Sat Sep 26, 2020 4:35 am ] | ||
| Post subject: | Re: Power steering pump alignment | ||
Quote: Quote: Quote: There are different PS pump pulley and pump mounting brackets for the AC / PS 225 SL6 vehicles.
| Author: | Doctor Dodge [ Sat Sep 26, 2020 11:13 am ] |
This one has a much flatter pulley and longer pump mounting tabs on the bracket that aligns to the front pulley groove. DD |
| Author: | SlantSixDan [ Sat Sep 26, 2020 12:00 pm ] |
Yup, that's the key. The "with A/C" power steering pump bracket moves the pump rearward to clear the A/C bracketry, and the dished-forward pulley is used to keep the P/S belt groove aligned with the front sheave on the crank pulley. |
| Author: | Studebaker [ Sat Sep 26, 2020 4:27 pm ] |
Quote: This one has a much flatter pulley and longer pump mounting tabs on the bracket that aligns to the front pulley groove.
Thank you, this is helpful. I think I can modify my bracket to match the one in the picture.DD Thanks again! |
| Page 2 of 2 | All times are UTC-07:00 |
