It is currently Mon Nov 16, 2026 3:34 am
PostPosted: Fri Oct 23, 2020 11:09 am
I have a good used pump I am going to try it on.
PostPosted: Fri Oct 23, 2020 2:31 pm
Isn't the pump body cast metal???
Welding to cast metal (whether iron or aluminum) is definitely harder to do than plate steel or aluminum.
PostPosted: Fri Oct 23, 2020 4:53 pm
I think the aluminum could be welded Ok by the right person. I know a person! :D CAst Iron would be a little harder
PostPosted: Fri Oct 23, 2020 7:19 pm
Car Model: '23 T-bucket
I wonder........ I know McMaster-Carr sells aluminum pipe fittings. I wonder if a good aluminum welder could weld a 1/2 female pipe union onto that cut off casting to get something similar to the Aussie casting?
Yeah.....take a peek at this. https://www.mcmaster.com/aluminum-pipe- ... -fittings/
Just an idea.
Roger
Users browsing this forum: Ahrefs [Bot] and 7 guests
