Oil filter relocation
https://slantsix.org/forum/viewtopic.php?t=65444
Page 2 of 2
Author:  Badvert65 [ Fri Oct 23, 2020 11:09 am ]
Post subject:  Re: Oil filter relocation
I have a good used pump I am going to try it on.
Author:  volaredon [ Fri Oct 23, 2020 2:31 pm ]
Isn't the pump body cast metal???
Welding to cast metal (whether iron or aluminum) is definitely harder to do than plate steel or aluminum.
Author:  Rick Covalt [ Fri Oct 23, 2020 4:53 pm ]
I think the aluminum could be welded Ok by the right person. I know a person! :D CAst Iron would be a little harder
Author:  GTS225 [ Fri Oct 23, 2020 7:19 pm ]
I wonder........ I know McMaster-Carr sells aluminum pipe fittings. I wonder if a good aluminum welder could weld a 1/2 female pipe union onto that cut off casting to get something similar to the Aussie casting?
Yeah.....take a peek at this. https://www.mcmaster.com/aluminum-pipe- ... -fittings/
Just an idea.
Roger
Page 2 of 2 All times are UTC-07:00
