Heat Riser Valve
https://slantsix.org/forum/viewtopic.php?t=65450
Page 2 of 2
Author:  slantfin [ Thu Oct 29, 2020 10:36 am ]
Post subject:  Re: Heat Riser Valve
[quote="cpslntdchrg"]Or you might be talking about the EGR
You were right, it's an EGR valve, which I thought was only found at the valve cover.
Author:  cpslntdchrg [ Thu Oct 29, 2020 11:43 am ]
Good we found what the vacuum port was for...
And... on the valve cover... you should have a PCV valve... that is good to have and should be in operating conditions.
Good luck solving your lean conditions. Using larger diameter jets makes sense to me.
Author:  slantfin [ Fri Oct 30, 2020 2:19 pm ]
Oh right, PCV is what I was thinking of, back to my ABC's!
Page 2 of 2 All times are UTC-07:00
