| 8 inch Ford JFI https://slantsix.org/forum/viewtopic.php?t=65685 |
Page 2 of 2 |
| Author: | Rob Simmons [ Wed Jan 06, 2021 12:22 pm ] |
| Post subject: | Re: 8 inch Ford JFI |
What the good doctor said, Charlie! |
| Author: | Greg Ondayko [ Wed Jan 06, 2021 2:56 pm ] |
Try these Charrlie.. https://www.summitracing.com/search/par ... =Ascending If you are pressing them in a skosh over .545 cant hurt. Greg |
| Author: | Charrlie_S [ Wed Jan 06, 2021 4:16 pm ] |
Yeah, I saw those ARP studs, but I'll be dammed if I'm going to pay more for 10 studs, then the complete brake job, including drums. $12 each. Time to get out the drill, and use Mopar studs. Remember, I'm "frugal" (cheap) |
| Author: | Tim Keith [ Sun Jan 10, 2021 8:35 pm ] |
My '73 Swinger had a 8-inch when I got it. I think the Toyota 8-inch is good too, some have the 5 x 4.5 inch(114.3 mm) pattern - some have six bolt "chevy" truck pattern - or Nissan truck etc, but I believe axle shops can make new shafts as the Toyota rear ends are popular for off-roading. I think the 2WD Toyota trucks use the 5 lug wheels, the 6 lugs are 4WD |
| Author: | Charrlie_S [ Mon Jan 11, 2021 4:27 am ] |
Quote: My '73 Swinger had a 8-inch when I got it. I think the Toyota 8-inch is good too, some have the 5 x 4.5 inch(114.3 mm) pattern - some have six bolt "chevy" truck pattern - or Nissan truck etc, but I believe axle shops can make new shafts as the Toyota rear ends are popular for off-roading. I think the 2WD Toyota trucks use the 5 lug wheels, the 6 lugs are 4WD
I have the 5 on 4.5 pattern on my 86 Toyota 1 ton single rear wheel, 2 wd. I would concur, that it is a good rear. Never had a problem with it, in over 400,000 miles, and towing my racecar. 5 speed stick. Have been on the scale at just under 5 tons total.
| Author: | emsvitil [ Mon Jan 11, 2021 4:43 am ] |
There's 2 versions of the Toyota 8" axle. A 4 pinion (aka V6 and turbo 4) and 2 pinion (aka 4 cyl). Not sure if the 1 ton axle is a 2 or 4 pinion. Most of the 2wd toyota's were 7.5" |
| Author: | Charrlie_S [ Mon Jan 11, 2021 8:15 am ] |
Quote: There's 2 versions of the Toyota 8" axle.
Not sure what is in mine, 1986 one ton PU 2 WD 22RE 5 spd. rear ratio is 4.30 All I know is it is/was a great truck, and I would buy another one in a heartbeat, if they still made them. I got 18 mpg towing and 25 mpg empty on the hiway. Never had the head off. Had the pan and timing cover off, to do 3 timing sets (plastic guides would break).
| Author: | Tim Keith [ Tue Jan 12, 2021 1:06 am ] |
Quote: Quote: There's 2 versions of the Toyota 8" axle.
Not sure what is in mine, 1986 one ton PU 2 WD 22RE 5 spd. rear ratio is 4.30 All I know is it is/was a great truck, and I would buy another one in a heartbeat, if they still made them. I got 18 mpg towing and 25 mpg empty on the hiway. Never had the head off. Had the pan and timing cover off, to do 3 timing sets (plastic guides would break).A 4 pinion (aka V6 and turbo 4) and 2 pinion (aka 4 cyl). Not sure if the 1 ton axle is a 2 or 4 pinion. Most of the 2wd toyota's were 7.5" Apparently Toyota trucks with a VIN starting with JTX where X = "G" has an 8-inch. "JTF" would be 7.5-inch. |
| Page 2 of 2 | All times are UTC-07:00 |
