| Romac timing chain - install sprocket before or after putting crankshaft in block? https://slantsix.org/forum/viewtopic.php?t=65694 |
Page 2 of 2 |
| Author: | Charrlie_S [ Thu Jan 21, 2021 5:02 am ] |
| Post subject: | Re: Romac timing chain - install sprocket before or after putting crankshaft in block? |
I don't peen the bushing. As stated it can't turn, if the hole is the correct fit, and the washer will keep the bushing from falling out. |
| Author: | Dart270 [ Thu Jan 21, 2021 7:53 am ] |
Same here. Never a problem. Washer is plenty big and the bolt torque (friction) holds the cam from turning relative to the gear, not the bushing. Lou |
| Page 2 of 2 | All times are UTC-08:00 |
