It is currently Mon Nov 16, 2026 3:35 am
Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Mar 21, 2021 9:42 pm
Here you go. These will work just fine.
https://www.summitracing.com/parts/hrs-91774/make/dodge
Are you sure? :?
PostPosted: Sun Mar 21, 2021 10:02 pm
Are you sure? :?
You see where it says "Dodge and AMC"? AMC engines only oiled through the pushrods to the heads, just like a Chevrolet. If you want to be 100 SURE, call Howards and inquire about that part number. I am certain enough that I would buy them. But since I am recommending them to you, please call. This has pretty much become the standard across the board for Chrysler hydraulic lifters since the AMC also uses the same .903 lifter diameter. This cuts production costs since manufacturers can make one lifter to suit both makes.
PostPosted: Mon Mar 22, 2021 8:03 am
That's only true for an engine that has an oil gallery feeding the lifters. We do not have that. Our hydraulic lifter engines are fed oil from the pushrod not to the pushrod.
PostPosted: Mon Mar 22, 2021 5:29 pm
AMC's oiled the lifters from the top down through the pushrods like a hydraulic Slant. If you read the Q&A it appears they think the AMC has lifter oiling in the block. I would definitely call and ask questions.
PostPosted: Mon Mar 22, 2021 5:35 pm
I'm looking at AMC blocks and they have lifter oil galleys so I don't know why the oiling would be top-down like the hydraulic lifter 225.
PostPosted: Mon Mar 22, 2021 9:46 pm
Hmmmmm, I've been told that hydraulic Slant lifters were AMC. Apparently I've been misinformed. In that case the OP is screwed.
PostPosted: Tue Mar 23, 2021 4:44 am
According to the "Buyers guide" the Sealed Power lifter for the 86 D-150 slant six is HT2089. That number does not cross over to any AMC engine. Only application listed is for the hydraulic slant six
PostPosted: Tue Mar 23, 2021 5:36 am
I've seen listings before that show that same lifter fitting 318s and 360s too, talk of having to use those lifters when putting magnum heads on an LA block, that oil the rocker arms thru the pushrods since original small block mopar lifters didn't have a hole in the pushrod seat.
Have also heard that some companies consolidated those numbers in their catalog anyways because they were otherwise the same dimensions between them except for that hole in the pushrod seat.
And taking that a bit further, having just gotten my reground cam back, I also got my new lifters from the same place and the call out on the receipt says they sold me "273 solid lifters" even though I'm really working on a slant. So it seems to "come around".
PostPosted: Tue Mar 23, 2021 9:01 am
The Chrysler and AMC lifter bodies are the same dimension. It is the way the hydraulic lifters receive oil that is the sticking point. No production slant six block has a lifter oil galley to fill the hydraulic lifter with oil.
Let's not confuse the original poster by bringing solid lifters into this discussion.
PostPosted: Tue Mar 23, 2021 10:29 am
If the cylinder head is getting oil (rocker shafts) wouldn't it work the same if you used the proper rockers? In other words, if a stock hydraulic lifter can get oil from the pushrod, couldn't a hydraulic roller lifter also get oil that way?
PostPosted: Tue Mar 23, 2021 11:05 am
As was pointed out, the hydraulic lifter 225 uses a unique lifter. Only if the guts from that special hydraulic lifter will fit a roller lifter body can it be fed from the top down.
I am dismayed by the demonstrated lack of understanding around the principles of operation of the hydraulic lifter and the simple fact that the slant six block cannot use conventional side-fed hydraulic lifters due to the lack of an oil gallery to feed them.
PostPosted: Tue Mar 23, 2021 11:11 am
Ok. I'm very familiar with how the hydraulic slant lifter works. More so than you, evidently. Good luck with it then!
PostPosted: Tue Mar 23, 2021 11:49 am
Then please describe the operation of the slant six hydraulic lifter. Describe the differences between the solid lifter slant six valve train, the hydraulic lifter slant six valve train and contrast that with the hydraulic lifter valve train of the V-8. If you cannot I am happy to do so and put this issue to rest.
PostPosted: Tue Mar 23, 2021 4:39 pm
No, it won't put anything to "rest". The slant six oils "backwards" so the lifter gets its oil from the top not the bottom.
The slant six lifters are the same as any other. If you think for one second the industry is going to change lifter design over ONE application, you're mistaken. I've had them apart. I've run solids, I've run hydraulics, I've run Rhoads and anti pump lifters. They all function in the slant six just fine.
It doesn't matter to "me" what you run, or what you "think" you know from reading forums with the wrong information. The slant six hydraulic LIFTER is nothing different than any other, although the oiling system is a little unique.
PostPosted: Tue Mar 23, 2021 5:35 pm
So explain how conventional hydraulic lifters work in a 225. What's the problem with explaining and increasing everyone's understanding?
Users browsing this forum: Ahrefs [Bot] and 10 guests
