| Roller Rockers https://slantsix.org/forum/viewtopic.php?t=66333 |
Page 2 of 2 |
| Author: | slantzilla [ Thu Dec 09, 2021 2:52 pm ] |
| Post subject: | Re: Roller Rockers |
Mine got a couple pushrods and cups too. RAS blamed that on bad Crane adjusters. They did send a new set of adjusters. I think Mike bought that mess from me. |
| Author: | DadTruck [ Mon Dec 13, 2021 10:54 am ] |
The second photo in the first post, the one with the rocker on its side, shows an oil groove, centered in the bushing and the feed holes that lead to the roller tip and the adjuster end intersect with that oil groove. I cannot say if the oil groove like the one shown in the photo is common or not in all other roller rockers, but the set that I have has oil grooves and that is what I intended to show in that photo. |
| Author: | CNC-Dude [ Mon Dec 13, 2021 12:10 pm ] |
It's hard to tell from the pic, but can you compare the groove depth to a stock rocker. If and when you get around to installing them on an engine, it would be interesting to see how much oil reaches the rockers and cups and tips if you prime the pump. |
| Author: | DadTruck [ Mon Dec 13, 2021 7:13 pm ] |
Quote: It's hard to tell from the pic, but can you compare the groove depth to a stock rocker. If and when you get around to installing them on an engine, it would be interesting to see how much oil reaches the rockers and cups and tips if you prime the pump.
no problemo, I will get a video, I am running a hydraulic cam reground to a mechanical grind with a hydraulic head, with a mechanical set of lifters, so there is full time oiling, plenty of oil to the top end and in fact i have been trying to reduce the top end oiling as I think t is overwhelming the positive valve seals. That may change with the roller rockers, will see where this goes.
| Page 2 of 2 | All times are UTC-08:00 |
