| Math wizards please step inside https://slantsix.org/forum/viewtopic.php?t=66395 |
Page 2 of 2 |
| Author: | GregCon [ Fri Jan 07, 2022 3:48 pm ] |
| Post subject: | Re: Math wizards please step inside |
Not compressed thickness, compressed volume. The average gasket (not sure about Slant Sixes) is not a perfect circle, nor is it the bore diameter. So the compressed thickness takes all of that into account and gives you what really matters, the volume in its installed condition. |
| Author: | Rick Covalt [ Fri Jan 07, 2022 6:28 pm ] |
I think you all are splitting hairs here. .1 or .2 either way in a race motor isn't going to make much if any noticeable difference. There are a hundred different things in the car and engine that come into play that will make that .1 hard to measure. Sure we want a close idea and that is all the calculators are doing. I'm pretty sure a Slant 6 head gasket opening is round. It definitely is not square PS. Dennis, See what you started! |
| Author: | slantzilla [ Sat Jan 08, 2022 6:07 am ] |
Bottom line is that when it's in the car and running I can say whatever number I want. With a 5200 stall and 4.86 gears .1 or .2 of compression won't matter. |
| Author: | DadTruck [ Sat Jan 08, 2022 7:37 am ] |
Quote: Not compressed thickness, compressed volume.
yea but to get the compressed volume one starts with the gasket diameter and the compressed thickness of the gasket and the formula shown below,V=pi*radius squared*height the online calculators use the diameter of the head gasket to get the radius and the compressed thickness of the head gasket to get the height, the compressed gasket volume is then just doing the math using the inputs. |
| Author: | Rob Simmons [ Sat Jan 08, 2022 8:53 am ] |
Quote: Bottom line is that when it's in the car and running I can say whatever number I want.
That’s what I dun with my motor fer awhile… ‘til Howard measured stuff & set me straight… |
| Author: | slantzilla [ Sat Jan 08, 2022 9:22 am ] |
The only number that matters is the MOV on the timeslip. |
| Page 2 of 2 | All times are UTC-07:00 |
