Timing chain help
https://slantsix.org/forum/viewtopic.php?t=66616
Page 2 of 2
Author:  Slantsix83 [ Fri Jul 08, 2022 2:39 pm ]
Post subject:  Re: Timing chain help
Out-of-index distributor is more likely than jumped timing chain; see here.
If you want to check for a slack timing chain, that's easy; see here.
Fixed the issue had to replace the coil again and ignition. Now I'm having a start and run issue. With the air filter on it start but when the engine start to warm up it dies. So I remove the air filter and it drives. Is this a vacuum leak or is this something I have to adjust .
Author:  Rick Covalt [ Fri Jul 08, 2022 6:16 pm ]
Did you plug all the vacuum fittings on the carb that were open? Did you check for vacuum leaks around the carb, intake, etc.
If it runs , check your timing and get it set. Adjust idle and idle mixture.
What exactly do you mean by ignition? The ignition module? The distributor?
Author:  Slantsix83 [ Sun Jul 10, 2022 3:00 pm ]
Are the vacuum fittings all the open holes on the carb? Yes the coil and ignition module. Is my distributor supposed to have a relay?
Author:  Rick Covalt [ Sun Jul 10, 2022 4:36 pm ]
No not normally. Can be a relay if someone switched the ignition system over to the HEI module.
Not necessarily. Check if you have vacuum on them when it is running. Or spray a little 2+2 into the open fittings. It will shut the engine off or change its sound greatly.
Did you set the timing and adjust the carb?
You may do well to post a video for us to see exactly what it is doing.
Page 2 of 2 All times are UTC-07:00
