It is currently Tue Nov 10, 2026 9:23 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Sep 16, 2024 2:28 pm
. and with all the glaring seemingly non-focused beam patterns on modern cars of the last ~5 years, .
More than anything I suspect that it is the proliferation of trash PNP hid bulbs in halogen housings AND high intensity LED systems in suv/trucks that have a high stock ride height.
PostPosted: Wed Oct 16, 2024 4:02 pm
A quick question and note:
Checking my '64 Parts Manual (only year I've got), I find that the 2095 430 pulley is specified for everything, with the exception of all A/C cars (2095 059, 3") and 426 cars (2095 662, 3-1/2").
Measuring my presumed-original pulley shows about 3-1/4".
So, it looks like the breakdown is:
  • 2-1/2" Single 2444 478
    3" Double 2095 059
    3-1/4" Single 2095 430
    3-1/2" Double 2095 662
A search yields one aftermarket Chinesium pulley for sale in several places, showing interchange with both 2095 430 and 2444 478, with a claimed diameter of 68mm (2-11/16"), which will spin 1.2 times faster than a standard 3-1/4" pulley.
It is here on eBay and here on Amazon, both for $16.
I am considering buying one and checking it out. Seems to me a slant-six with a 904, which probably shifts at 4,500 RPM (sorry, I don't have a tach connected) won't turn enough revs to over-rev the alternator.
Question: Any reason for me to believe I'm wrong, and turning the alternator 1.2 times faster during those dramatic highway passing moments will injure it?
Sneaky second question: Anyone think trying this crappy pulley would be a bad idea?
Daring third question: It looks like the pulley is an interference fit on the shaft and has to be pulled off with a special tool and reinstalled with a press. True? Seems a bit involved. Can one actually do this, or is it so involved as to be absurd if everything is working fine anyway?
Thanks,
– Eric
PostPosted: Wed Oct 16, 2024 7:41 pm
No.
Yes.
Anyone think trying this crappy pulley would be a bad idea (…) if everything is working fine anyway?
Yes.
PostPosted: Thu Oct 17, 2024 6:24 am
No.
Yes.
Yes.
Thank you.
PostPosted: Thu Mar 13, 2025 6:26 am
I Found the Source of my problem, it was the alternator. Upon Further inspection, I already had the 2444 478 pulley installed.
It was measured as a 2 3/4" outer Ø pulley.
The other ones that I have access to were a bit bigger, @ 2.9" outer Ø I could not find a part # on this rusty hulk.
Anyway, I kept the 2444 447 Pulley as it was smaller and then I Also Found that 2 of the diode wires in the back of the alternator became unsoldered and loose. I fixed that so now It is slow idling with the headlights on at ~12.5-12.7 V and the Full charge when spinning over 2500 RPM is ~ 14.2-14.3V
Now to repair that starter solenoid.. and check on some other things.
Thanks guys!
