| Upgrade 1976 727 with parts from a 1999 A-518? https://slantsix.org/forum/viewtopic.php?t=68329 |
Page 2 of 2 |
| Author: | Reed [ Fri Aug 22, 2025 7:39 pm ] |
| Post subject: | Re: Upgrade 1976 727 with parts from a 1999 A-518? |
Quote: Quote:
I do know the A500 and A518 share the same Borg Warner overdrive unit Mmm…no, sir. There is no Borg-Warner overdrive in either of those transmissions. They were in-house designed, in-house built by Chrysler.
D'OH! Dan strikes again. I hadn't looked closely at these transmissions for over a year, so I got it wrong. I just looked closer and it is not Borg Warner, but NEW PROCESS. I knew it was one of those gear companies. Whoops. |
| Author: | SlantSixDan [ Fri Aug 22, 2025 9:08 pm ] |
New Process was Chrysler's gear operation for quite a long time. In '90 there was a GM tie-in and a rename to New Venture. In '12, the whole outfit closed down. Good history in the Wiki: https://en.wikipedia.org/wiki/New_Venture_Gear |
| Author: | Charrlie_S [ Sat Aug 23, 2025 12:56 am ] |
I think you are thinking of the "old" Borg Warner OD units, that were used by many car manufactures back in the '50's, and '60's. They mounted onto the rear of a 3 speed standard shift trans with an adapter plate. Chevy, Ford, and Chrysler (probably others) all used them and they were almost identical to each other.I had several cars with them. Really liked them. I had one car that I put together for towing one of my race cars. 1962 Chevy Convert, 348 engine, with the 3 speed stick on the floor, and the BW overdrive. Had a electric switch on the shifter, to manually control the OD. I could do "split shifts". 1st, 2nd, 2nd od, 3rd, 3rd od. Just like a truck with a 2 speed rear. |
| Author: | Greg Ondayko [ Sat Aug 23, 2025 4:23 am ] |
Reed, I would Just Call A& A trans in Camby IN, and see if you can speak to Rick Allison there. He can guide you through and answer your questions. Greg |
| Author: | Reed [ Sat Aug 23, 2025 11:59 am ] |
Thanks. Charlie- I was misremembering. The overdrive units are not Borg Warner, they are New Process. But that are the same between the A500 and A518. Greg- I might do that if visual inspection and comparison of the parts suggests something might actually be swappable. Now I just need to carve out the time to pull the 727 and put it on my workbench next to my bucket of A518 parts. |
| Page 2 of 2 | All times are UTC-07:00 |
