| Clutch no longer available? https://slantsix.org/forum/viewtopic.php?t=68767 |
Page 2 of 2 |
| Author: | Rick Covalt [ Sat Sep 26, 2026 9:20 am ] |
| Post subject: | Re: Clutch no longer available? |
Did you read the link I posted? Yes you can install a flat small block flywheel with 130 tooth. Ours was a high starter as well. Here is the picture of the flywheel. Attachment:
| Author: | arms [ Sat Sep 26, 2026 9:34 am ] |
Cool. Thats the flywheel all right. So just get a 130 flat and clutch. Same bell housing? I’ll get the clutch and flywheel to have on hand. I did read back on your previous post. Thanks a lot! |
| Author: | arms [ Sat Sep 26, 2026 9:36 am ] |
I’m guessing to fit the 11” they had to recess disc into flywheel. |
| Author: | Rick Covalt [ Sat Sep 26, 2026 2:11 pm ] |
Yes same bell housing. You just have to drill the one hole in the v8 flywheel to fit the slant 6 crank pattern. |
| Author: | arms [ Sat Sep 26, 2026 2:36 pm ] |
Awesome! Thanks so much. |
| Page 2 of 2 | All times are UTC-07:00 |
