It is currently Sun Nov 29, 2026 3:40 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Re: Over center spring
PostPosted: Wed Nov 04, 2026 10:46 am
This will make it all better:
https://www.brewersperformance.com/prod ... up-a-body/
PostPosted: Wed Nov 04, 2026 2:07 pm
Car Model: 1971 Scamp
Thanks Greg!
PostPosted: Wed Nov 04, 2026 5:34 pm
Apparently these folks in Australia have them? They also list a heavy duty one for $277. Probably way too expensive to get it here.
https://www.plumkrazygarage.com.au/prod ... it-slant-6
PostPosted: Wed Nov 04, 2026 5:45 pm
Buying a wear item that I can only source from AU is not very appealing to me. I appreciate you searching that out for me though!
PostPosted: Thu Nov 05, 2026 6:38 am
I also noticed this on the aussie site:
https://www.plumkrazygarage.com.au/prod ... eq=uniform
Nice find, Rick. Who knows how HD this is, but it's a part!
PostPosted: Thu Nov 05, 2026 9:41 am
Shipping is $111. I think if you need something other than stock the Ram clutch and flywheel combo makes the most sense. Buy once and (hopefully) cry once.
I ended up going with the Autozone clutch. It has a lifetime warranty and I’ll allow myself 2 replacements before I’ll eventually upgrade to the Ram setup. I think the Duralast clutch should be fine behind the stroker, but probably not the new long rod motor.
PostPosted: Fri Nov 06, 2026 5:21 am
Did you get the 9.25" stock size clutch or the 10"? The 10" works fine and has more holding power unless you don't torque the PP bolts enough (and loctite), OR you do high RPM clutch dumps. Then you might blow it up and hurt car, engine block, feet...
PostPosted: Fri Nov 06, 2026 7:44 am
The 9.25 so I’m replacing the clutch disc and not my feet.
