No Hot Air
https://slantsix.org/forum/viewtopic.php?t=7531
Page 2 of 2
Author:  mighty mouse 63 [ Sat Nov 15, 2003 3:37 pm ]
Do you have access to a marine hardware store? If so, you can get crimp on metal furrels to secure the loops if no luck try a bike repair shop, I prefer the marine ones in stainless steel.
Author:  killin5 [ Sat Nov 15, 2003 4:07 pm ]
I was thinking about crimping something on.
Another idea may be...
At the end of each cable, there is a round piece of metal attached. This fits in to the brake lever. It may be possible to drill a hole in this piece of metal and use it in place of the loop. You may be able to crimp the other end to the cars control.
I have not looked closely at the setup in my car lately, so this is all theory.
John
Author:  64 Convert [ Sat Nov 15, 2003 5:22 pm ]
What year and model is your car. I have a couple of cables up in my attic.
Author:  Pierre [ Sat Nov 15, 2003 5:59 pm ]
I just finished making the kinked cable out of the steel wire and am in the process of reinstalling it in the car. Seems to work ok.
I noticed the vent hoses were all jacked. The local stores only had hose that was the same size on both ends, so I got a length that matched the bigger vent end and will have to use something, probably a wire tie on the smaller end that goes in the box. A 6 foot length of 2 1/2" h se was $28 after tax. Ouch! But it was of a plastic material, seems that it will last longer then the original paper ones.
Page 2 of 2 All times are UTC-07:00
