| GodsRods Duster II https://slantsix.org/forum/viewtopic.php?t=39102 |
Page 11 of 47 |
| Author: | Rob Simmons [ Wed Jun 29, 2011 8:55 am ] |
Yup. The story of my life... I'm plugging away at things slowly,... very slowly. Just getting the garage cleaned up and getting my work bench and tool box over there really is going to make a difference in things I think. It sure would be nice to be at a point where I could consider doing some testing. One step at a time. Have fun at 41! |
| Author: | Dart270 [ Wed Jun 29, 2011 9:27 am ] |
Sounds good, Dennis. Would be great to see you and the Piggie at Clay City for some coooold D/gas record setting... Lou |
| Author: | slantzilla [ Wed Jun 29, 2011 2:05 pm ] |
Supposedly neither of my machines will run Saturday, but I'll believe that when I walk out at 3 tomorrow and they are not posted. Lou, OT seems to be picking up again, so there is a decent chance I'll be there. |
| Author: | wvenable [ Wed Jun 29, 2011 2:46 pm ] |
Big D, better check with possum. Ya Chic - carr -go boys may need some kinda visa to wander that far south! |
| Author: | Rob Simmons [ Thu Jun 30, 2011 10:07 am ] |
| Post subject: | Re: "Mad Thrash" Update |
1. [X] Replace brake line to rear of car 2. [_] Either swap in the 8 3/4 (3.91 Sure Grip) and driveshaft from Street Duster or fix the leaky axle seal on the Ford 8" (4.56 Mini Spool) and get another driveshaft 3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Will use the SBP Drums at least for Elk Creek 4. [_] Install fuel cell, lines, pump, etc. 5. [_] Install wiring and gauges (ignition, tach, water, oil...) 6. [/] Buy and install a carb / linkage / gas pedal 7. [_] Install radiator 8. [_] Buy and install trans cooler and lines 9. [_] Install seats and harnesses 10. [/] Polish and reinstall lexan windshields 11. [_] Cover a hole in the driver side floorboard 12. [_] Paint floors and roll bar 13. [X] Install Line Loc 14. [X] Reinstall Driveshaft Loop 15. [X] Clean and organize garage for better productivity/safety 16. [_] Install water pump pulley 17. [_] Decide whether to run an alternator or get a battery charger 18. [/] Probably another dozen things I haven't thought of yet! Stuff in BOLD is an update since last time. The / means the task is only partially completed. Once the task is completed it will change to X. One more X Dennis... |
| Author: | Doc [ Thu Jun 30, 2011 10:28 am ] |
Give yourself a "slash" for item 18... seeing that you are thinking about all the stuff you have not thought of yet... DD |
| Author: | Rob Simmons [ Thu Jun 30, 2011 10:39 am ] |
Good idea Doc! I need all the help I can get! |
| Author: | slantzilla [ Thu Jun 30, 2011 2:17 pm ] |
Quote: Big D, better check with possum. Ya Chic - carr -go boys may need some kinda visa to wander that far south!
Visa? We don' need no steenking Visas! |
| Author: | sandy in BC [ Thu Jun 30, 2011 3:07 pm ] |
| Post subject: | Possum / Visa |
you Dont need a Visa. But you may need a hand gun. Dennis and I went to the South to visit Lou . No Visa......and passable seafood. Im still not sure about biscuits and gravy as a takeout breakfast........Their coffee is OK Possum snuck me into a slant race once.....didn t even need a pit pass. No cash or Visa. He is fast in every way. Not just foot braking..... |
| Author: | Rob Simmons [ Thu Jun 30, 2011 7:15 pm ] |
I think Possum might show up at Clay City this year Sandy. You should come too! Long time promoter of Clay City, Bobby Rogers, is planning to attend (and hopefully race with us). |
| Author: | Rob Simmons [ Sat Jul 02, 2011 6:14 am ] |
| Post subject: | More progress! |
1. [X] Replace brake line to rear of car 2. [_] Either swap in the 8 3/4 (3.91 Sure Grip) and driveshaft from Street Duster or fix the leaky axle seal on the Ford 8" (4.56 Mini Spool) and get another driveshaft 3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Will use the SBP Drums at least for Elk Creek 4. [X] Install fuel cell, lines, pump, etc. 5. [_] Install wiring and gauges (ignition, tach, water, oil...) 6. [/] Buy and install a carb / linkage / gas pedal 7. [_] Install radiator 8. [_] Buy and install trans cooler and lines 9. [_] Install seats and harnesses 10. [/] Polish and reinstall lexan windshields 11. [_] Cover a hole in the driver side floorboard 12. [_] Paint floors and roll bar 13. [X] Install Line Loc 14. [X] Reinstall Driveshaft Loop 15. [X] Clean and organize garage for better productivity/safety 16. [_] Install water pump pulley 17. [_] Decide whether to run an alternator or get a battery charger 18. [/] Probably another dozen things I haven't thought of yet! I got the fuel cell, pump, lines and regulator installed last night! Gerald is freshening up a 600 CFM Double Pumper and sending it to me. Stuff in BOLD is an update since last time. The / means the task is only partially completed. Once the task is completed it will change to X. |
| Author: | Rob Simmons [ Tue Jul 05, 2011 7:16 am ] |
| Post subject: | Wiring stuff partially done |
1. [X] Replace brake line to rear of car 2. [_] Either swap in the 8 3/4 (3.91 Sure Grip) and driveshaft from Street Duster or fix the leaky axle seal on the Ford 8" (4.56 Mini Spool) and get another driveshaft 3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Will use the SBP Drums at least for Elk Creek 4. [X] Install fuel cell, lines, pump, etc. 5. [/] Install wiring and gauges (ignition, tach, water, oil...) 6. [/] Buy and install a carb / linkage / gas pedal 7. [/] Swap radiator with one from Dart 8. [_] Buy and install trans cooler and lines 9. [_] Install seats and harnesses 10. [/] Polish and reinstall lexan windshields 11. [_] Cover a hole in the driver side floorboard 12. [_] Paint floors and roll bar 13. [X] Install Line Loc 14. [X] Reinstall Driveshaft Loop 15. [X] Clean and organize garage for better productivity/safety 16. [_] Install water pump pulley 17. [_] Decide whether to run an alternator or get a battery charger 18. [X] Bleed brakes 19. [X] Install A/C in garage 20. [/] Probably another dozen things I haven't thought of yet! I got the fuse panel, tach and gauges installed this weekend. Mike and CJ helped me bleed the brakes. Took the time to get my window A/C unit up off the floor and installed in the side door. The door has been bolted shut, so it was a good place for it for now. I decided to swap the aluminum radiator into the street Dart and use the stock radiator from the Dart in the Duster. The aluminum radiator has the larger lower hose outlet. When I swapped the V8 into the Dart I just cut a section of the stock lower hose and doubled it up to make the larger hose fit. Stuff in BOLD is an update since last time. The / means the task is only partially completed. Once the task is completed it will change to X. |
| Author: | Rob Simmons [ Tue Jul 05, 2011 8:48 am ] |
| Post subject: | Pics!! |
My "Brake Bleeders" ![]() ![]() ![]() Mischa the "Shop Dog" with her favorite ball ![]() ![]() Me
| Author: | Dart270 [ Tue Jul 05, 2011 8:58 am ] |
Great pics!! Have fun! Lou |
| Page 11 of 47 | All times are UTC-07:00 |
