Another Offy group Buy?
https://slantsix.org/forum/viewtopic.php?t=48833
Page 11 of 12
Author:  Rob Simmons [ Tue Oct 02, 2012 11:59 am ]
You guys better quit talkin' this up so much! It makes me want a nifty valve cover for Chase's Demonster... :lol:
Author:  65 dartman [ Tue Oct 02, 2012 2:26 pm ]
UPS just delivered my valve cover and dual single manifold as well. Guess I better get cracking on fabricating another stovepipe for this one just like my other one.
Author:  GTS225 [ Tue Oct 02, 2012 7:58 pm ]
Rob....there's an extra voice in your head, now. It's a valve cover whispering "buy me, buy me". :lol: :wink:
Sidebar ! You guys that bought the 2x1 intake.....if you plan on mounting Holley 1920's, check your carb flange bolt pattern soonest. I wanted to use Holley 1904's, and the bolt pattern is smaller on the carb than it is on the manifold. I may be wrong, but I think the 1904 and 1920 uses the same flange pattern. I'm already in the planning stages of fabricating an adapter for this. (Also working on a water heat manifold for plenum heat, as I wanted to run headers.)
Roger
Author:  ro23dart [ Thu Oct 04, 2012 7:26 am ]
Would you be interested in fabricating a stovepipe and baffles for mine? I would pay you for the time and materials. I really like the looks of the previous one you did and figured since you had already done it before you would probably be the expert.
Author:  65 dartman [ Thu Oct 04, 2012 7:36 am ]
Believe me, I'm no expert - just winged it. I just cut and formed the the sheet aluminum for the shape of the baffles and rolled the aluminum till I got the correct size for the PCV cap. I had someone else TIG the stovepipe together and TIG it as well as the baffles to the valve cover. I had them hole saw the valve cover since they were doing the other work. Anyway, drop me a PM.
Author:  mrhollywood [ Thu Oct 04, 2012 1:07 pm ]
Got my 4bbl intake in yesterday! Damn it's light compared to my original! :D
Author:  wvenable [ Wed Oct 17, 2012 4:52 am ]
I assume everyone got their parts and things look good. I know my dual carb intake is looking mighty fine. Remember Dan might have a few extras if you were sittin' on the fence. Thanks to Dan and the rest of you guys for making another group buy a success.
Author:  64ragtop [ Wed Oct 17, 2012 2:50 pm ]
dmarv, P.M. sent.
ATB
BC
Author:  Jeb [ Thu Oct 18, 2012 3:07 am ]
Quick question,
Will the intake retain it's cast aluminum appearance once installed on the engine, or will it start to corrode?
Author:  CNC-Dude [ Thu Oct 18, 2012 9:25 am ]
I have seen a lot of people spray their intakes with a clear polyurethane coating to protect them from the oil grime and road dirt that always finds itself making the intake look grungy. Its slick finish keeps the dirt and stuff from getting into the pores of the aluminum making it harder to keep clean otherwise. You might try that.
Author:  Dltarnnr [ Fri Oct 19, 2012 12:12 pm ]
Just curious what a dual 1bbl manifold do verse just running a 2bbl ?
Author:  mcnoople [ Fri Oct 19, 2012 3:53 pm ]
Its cooler (not talking temperature either).
Author:  Fopar [ Fri Oct 19, 2012 4:46 pm ]
Better fuel distribution!
Richard
Author:  GTS225 [ Fri Oct 19, 2012 6:15 pm ]
Its COOLER (not talking temperature, either)
There, Mcnoople......fixed it for ya. :D :wink:
Roger
Author:  ceej [ Fri Oct 19, 2012 9:41 pm ]
It makes your linkages more complicated. :D
Page 11 of 12 All times are UTC-07:00
