It is currently Sun Nov 15, 2026 7:19 pm
Post new topic  Reply to topic  [ 163 posts ]  Go to page Previous 1 … 7 8 9 10 11
PostPosted: Wed Jan 28, 2015 11:03 pm
Car Model: 64 Valiant
Greg, Sandy hit it right on the head at 15'. It's easily tall enough for a car lift. I wouldn't go any smaller than a 50' x 100', you will fill it up quick before you know it.
PostPosted: Tue Jun 02, 2015 11:55 am
Any updates?
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Fri Jun 05, 2015 6:21 pm
Car Model: 1964 Valiant
I'd like one too !
PostPosted: Sun Jun 07, 2015 8:24 pm
The main problem is the enthusiasm to development cost ratio isn't anywhere close to where it needs to be to make this happen. Sorry!
PostPosted: Sun Jun 07, 2015 9:14 pm
So...it's dead?
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Sat Jul 11, 2015 9:51 pm
Car Model: '70 Barracuda /6 3spd
So...it's dead?
that would be sad. there are a lot of slants on the road and a need for a good bolt on EFI system
1970 Barracuda 225 /6, 3spd on the floor, Blue/Blue
PostPosted: Sat Aug 08, 2015 6:22 pm
Well, I may take another look at this project. It wouldn't really be that hard or costly to get a couple of prototypes made.
PostPosted: Sat Aug 08, 2015 6:42 pm
Instead of a complete new intake, what about a spacer that would fit between the head and the intake runners that would be nothing more than a fuel injector mount?
PostPosted: Sat Aug 08, 2015 7:14 pm
I think that would be just as hard and not near as efficient. You would then have to worry about intake/exhaust manifold alignment, unless you made the spacer for the exhaust and intake, but then that would make the exhaust pipe routing a little hard. Not to mention your injector angle would be less than optimum and you'd either have to run a honkin 4v throttle body meant for v8 apps, or another spacer for a more common and properly sized 99th. Just my $.02
1976 Dart Sport
Currently under revision
 Post subject: Reed has a point...
PostPosted: Sat Aug 08, 2015 7:59 pm
I was thinking the same thing when I saw this: http://www.ebay.com/itm/Slant-6-Six-Dod ... 0f&vxp=mtr
Not that this would be thick enough to give the right angle for the injectors, but it gave me the idea to use a thick piece like this to make an injector manifold that fits between the existing manifolds and the head. You'd need two gaskets, but Remflex's would solve any leak issues. And effectively you'd have longer runners.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Aug 08, 2015 9:17 pm
I wouldn't care it the spacers only were for the intake. If someone is converting to port fuel injection, they probably want to eliminate the manifold heating anyway. I intend to.
PostPosted: Wed Aug 12, 2015 5:10 pm
My main concern was more of if the air comes in from the front how much of that is moved to the back of the intake. It may be a moot point. Let me give an example if you bring in 60 cfm is each cylinder going to only take 10cfm or will they take what they can and leave the rest starving. On the flip side of this can there be to much air? How would it be dealt with if that does happen. Again I may just be waxing on but the main point of an intake is to provide air.
In a naturally aspirated motor, typical plenum volume is designed at, or close to, engine volume. This helps to ensure that sufficient air is available. Your concern is valid, but there's a lot of room between functional and perfect.
In a boost motor, the manifold is where boost should be measured; and the built-up pressure is regulated by the wastegate. When the wastegate opens, turbine and compressor rpm's drop and boost drops remains at the target.
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Sat Oct 03, 2015 10:20 pm
interesting
