It is currently Mon Nov 30, 2026 6:22 am
Post new topic  Reply to topic  [ 161 posts ]  Go to page Previous 1 … 7 8 9 10 11
 Post subject: Re: Volare project
PostPosted: Sun Nov 29, 2026 7:57 am
Anywhere you can but preferably not on the exhaust manifold. As long as it's screwed into the block or head.
PostPosted: Sun Nov 29, 2026 9:26 am
Thanks Don!
So the top of the cylinder head is ok?
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 11:35 am
Thanks Don!
If your ground will reach. It's all metal, and all bolted together. So it'll make contact. In fact put a 2nd one on somewhere. You can't have "too good" of a ground.
I lose sight of this all the time but a lot of electric faults are on the ground side of the circuit.
You wouldn't believe the gremlins that the lack of that light gauge pigtail off the negative side of the battery that often connects to the core support can cause...
On the connection you are questioning just remember paint can really screw with getting good continuity. Did you paint this engine? Might want to clean it away from right around that bolt hole and clean out the threads of paint, too.
PostPosted: Sun Nov 29, 2026 12:06 pm
Ok, so I'll make sure that the area has good bare metal contact.
Thanks Don!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 1:33 pm
Okay, the ground is secure, and I replaced those two fuel hoses yesterday.
When I crank it, fuel is still leaking from somewhere.
It looks like the passenger side of the engine onto the k-member, and onto the ground.
It doesn't look like its coming from the fuel pump.
I'm gonna get a friend to crank it while I watch with a flashlight.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 2:15 pm
Ok, upon closer inspection it is coming from the fuel pump.
The hose going to the carb is good, but where this hose connects to the fuel pump is the culprit.
Like, this outlet has a hole in it, its about to fall off the fuel pump.
How did I not see this earlier???
So I ordered a fuel pump which will arrive tomorrow.
Next weekends project.
At least I solved the mystery of where the fuel was leaking from.
Onward!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 6:26 pm
Make sure you aren't now overfull on oil
With these engines very often when the fuel pump does it fills the crank case with gas.
Oh and just curious so you still have the old engine that came out?
PostPosted: Sun Nov 29, 2026 6:35 pm
Yes, I do still have the original slant six.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 6:40 pm
IIRC, either a bolt hole in the head or a bellhousing bolt.
PostPosted: Sun Nov 29, 2026 6:53 pm
Thanks Dennis!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 29, 2026 7:15 pm
New fuel pumps are almost all absolute junk. I have had 2 new ones tight out of the box that leaked where the outlet fitting was crimped into the body. Don't even try to snug up the fittings without a backup wrench.
