Covalt - "Project 65 Valiant"
https://slantsix.org/forum/viewtopic.php?t=35632
Page 104 of 128
Author:  Badvert65 [ Sun May 30, 2021 1:15 pm ]
Post subject:  Re: Covalt - "Project 65 Valiant"
Wow, that looks awesome.
Author:  Greg Ondayko [ Sun May 30, 2021 2:06 pm ]
Nice work.
I need to make some plates like that for Grüne Hölle!
Author:  Rob Simmons [ Sun May 30, 2021 7:00 pm ]
Very nice work as always, Rick!
Author:  Rick Covalt [ Sun May 30, 2021 7:11 pm ]
I did make a tracing of the hood hinge brackets for you guys that wanted them. I actually drilled some holes in them so they are lighter. :D :D I'll make copies and send to Greg , Lou and Rob.
Author:  slantzilla [ Sun May 30, 2021 8:12 pm ]
Awesome stuff Rick!
Author:  Greg Ondayko [ Mon May 31, 2021 5:06 am ]
Thanks Rick!
It is possible that I might get to installing a fiberglass hood this year!
Author:  Dart270 [ Mon May 31, 2021 5:57 am ]
Super nice work, Rick.
Thanks again for tracing/sending your bracket designs!
Author:  Rick Covalt [ Mon May 31, 2021 11:42 am ]
Got some re-wiring done. Moved the radiator forward about 3/4" to get some needed room and got the fan and air duct in place. Fired the engine back up and ran until hot. Didn't have any leaks. Belts all stayed in place and looked good. Will recheck again tomorrow and possibly take for a drive. :D :D
Eventually I will get an aluminum panel for under the carb inlets to keep some of the heat away.
Author:  Rick Covalt [ Tue Jun 01, 2021 5:30 pm ]
I ran the car back up to temperature 180-190 two more times this evening. No leaks, and the electric fan works automatically and manually. Buttoned up some more small items, and installed the grill. Only thing I have to do is put the hood back on and align it. The alignment pin holes make that a snap. Almost ready for Wilkesboro. :D :D
Author:  Rick Covalt [ Sun Jun 06, 2021 11:44 am ]
Hood is back in place. One thing I will say that is the best thing I ever did was drill 2 1/8" alignment holes in the hood brackets. That way you can loosely mount the hood, insert the pins and tighten. Voila! Done. on a race car that has the hood off more than normal it is great.
Alignment pins
If anyone knows where to get some some sponge rubber spacers like on the hood pin let me know. I lost one and have no idea where I got he originals. They were just in my toolbox drawer! :D
Author:  emsvitil [ Sun Jun 06, 2021 3:53 pm ]
Would anti-roll bar end link bushings work for the spacers?
Author:  Rick Covalt [ Sun Jun 06, 2021 4:25 pm ]
These are a soft sponge rubber type material. It works nice with the glass hood. I adjust the hood so I just push down slightly into this little sponge rubber spacer and then hook my hood pin. It worked good until it ran away from home! :D :D
Author:  Badvert65 [ Sun Jun 06, 2021 4:56 pm ]
Rick, what are the dimensions of the rubber? I bought some soft foam rubber to use for gas line insulation. I think it is 3/8 inner diameter. It is a long tube, so it could be cut to any length. I'll have to get a pic of it for you.
Author:  Rick Covalt [ Sun Jun 06, 2021 5:35 pm ]
It is probably 1 1/4" I'd guess. 3/8" ID would work. I can measure tomorrow for sure. Thanks!
Author:  Badvert65 [ Mon Jun 07, 2021 3:55 pm ]
Rick,
The foam I have is one inch diameter with a 3/8 inch hole in the center. I think it might be originally for HVAC purposes.
If you want to give it a try, I can send you a foot or so. Just let me know.
Page 104 of 128 All times are UTC-07:00
