| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 12 of 12 |
| Author: | maxracer [ Tue Jan 04, 2011 7:15 pm ] |
| Post subject: | headers |
If your headers are built as well as your frame connectors then put me down for a set. Every piece foment ur shop has been 1st class. Max |
| Author: | Mister Twister [ Wed Jan 05, 2011 4:49 am ] |
The 170 65 Valiant - We have done some measuring on the new header set!! The front header has 54" of pipe total and the back has 51" of pipe. 3" spread between six pipes, around 1/2" per pipe difference!!! In my own way of thinking that is. Not equal but not a bad separation at all. It just came out that way after routing. Now here is the actual tube length on this set. (before collector) #1 21"- #2 18"- #3 15"- #4 16" #5 16"- #6 19" Tranny lines should be ok, they should sit 1" or 2" below where oil pan bolts are. That area has some room, it gets tight above the pan bolts. Thanks again Charrlie I will be working on the trap door today for ya Don |
| Author: | Mister Twister [ Thu Jan 06, 2011 5:39 am ] |
| Post subject: | Re: headers |
Quote: If your headers are built as well as your frame connectors then put me down for a set. Every piece foment ur shop has been 1st class.
Thank you for your kind words MaX, do you have them mounted yet? If so how did the install go? Some pics or a link would be nice. Looks like an inside day for me under the helmet Max |
| Author: | Mister Twister [ Sat Feb 05, 2011 5:27 am ] |
I should have the early A body 170 long tube headers done this weekend if all go’s well. I will post pics next week of the new design!! Soon as we finish these, I will start the turbo design. I wiil be making two different turbo style header. These will be for sale in march. If you had a choice, would you go with the turbo mounted where the battery was or the turbo mounting close to the motor? This will help on which design I will make more of, thanks for any input on this Don. |
| Author: | 65CrewCabPW [ Sun Feb 06, 2011 4:00 pm ] |
Quote: I should have the early A body 170 long tube headers done this weekend if all go’s well. I will post pics next week of the new design!! Soon as we finish these, I will start the turbo design. I wiil be making two different turbo style header. These will be for sale in march.
Do you have something that works on a W150? I'm looking for an exhaust the flows nicely and has no carb heat (run on propane). If you had a choice, would you go with the turbo mounted where the battery was or the turbo mounting close to the motor? This will help on which design I will make more of, thanks for any input on this Don. Thanks |
| Author: | mfdu [ Sun Apr 10, 2011 6:50 pm ] |
Hi Mster Twister. I've only just discovered your awesome header project. I posted this question on FABO, regarding the DC's - do you have any ideas on delivery cost to Australia? otherwise, availability of plans, so i can get them made up locally? (this is for a 1967 VC sedan - all steering / brakes are on the opposite side of the firewall to you, so there is really only start-motor clearance issues in common with you) i love the idea of duals running off the DC, with my twin-carb manifold running stock air cleaners - trying to make it look like it rolled off the factory like that. there is no problem getting shorty headers - everyone here in Oz runs extractors (AKA headers) because we have all the steering gear on the 'correct' side of the engine bay . . . typically, i don't want to do it the same as everyone else . . . chris. |
| Author: | terrylittlejohn [ Wed Apr 13, 2011 3:54 pm ] |
has there been any finial price set on the shorty headers and x-y pipe? |
| Author: | Mister Twister [ Fri May 06, 2011 3:44 am ] |
Quote: Quote: I should have the early A body 170 long tube headers done this weekend if all go’s well. I will post pics next week of the new design!! Soon as we finish these, I will start the turbo design. I wiil be making two different turbo style header. These will be for sale in march.
| Author: | Mister Twister [ Fri May 06, 2011 3:47 am ] |
Quote: Hi Mster Twister. I've only just discovered your awesome header project.
Don't know about shipping cost to you. You are looking in the right place for something different tho. I posted this question on FABO, regarding the DC's - do you have any ideas on delivery cost to Australia? otherwise, availability of plans, so i can get them made up locally? (this is for a 1967 VC sedan - all steering / brakes are on the opposite side of the firewall to you, so there is really only start-motor clearance issues in common with you) i love the idea of duals running off the DC, with my twin-carb manifold running stock air cleaners - trying to make it look like it rolled off the factory like that. there is no problem getting shorty headers - everyone here in Oz runs extractors (AKA headers) because we have all the steering gear on the 'correct' side of the engine bay . . . typically, i don't want to do it the same as everyone else . . . chris. |
| Author: | Mister Twister [ Fri May 06, 2011 3:56 am ] |
Quote: has there been any finial price set on the shorty headers and x-y pipe? Hello terrylittlejohn here is where I have them listed. http://www.stormcomm.net/moparsnmore/exhaust.html they are not multiable pieces any more just a couple for the X and Y THE We are up dating the page as we speak Don. |
| Author: | Mister Twister [ Fri May 06, 2011 4:19 am ] |
The changing of collector design is why the 170 early A bodys not finished yet! We have built the one of the turbo designs, with the turbo close to the motor. The ones for sale will have the flange mounted where the two 3" pipes come together. Then I will have two collector pipes made to run the turbo where the battery was or closely mounted like mine just finished. I will be rerouting the fuel line as well, running up top instead of from the front. Little kinky now! Thanks for any input on this, the BOV will be mounted just below the turbo Don. See the change here! http://www.youtube.com/watch?v=XmyoWFr- ... e=youtu.be |
| Author: | 6s\ant6 [ Fri May 06, 2011 5:49 am ] |
| Post subject: | Manifolds are awesome! |
Are the ones ready for turbo on your site yet? I didnt see them. |
| Author: | Turbo Toad [ Fri May 06, 2011 8:22 pm ] |
I too am interested in one of the turbo headers I pm'd u on FABO AARON |
| Page 12 of 12 | All times are UTC-07:00 |
