Best Times
https://slantsix.org/forum/viewtopic.php?t=5579
Page 12 of 12
Author:  Old6rodder [ Tue Apr 17, 2018 10:51 am ]
Post subject:  Re: Best Times
9.09 @ 139 Will 1967 Barracuda 15# boost 5/18/16 Mason Dixon Dragway
9.85 @ ??? The Drakes, 1938 Simca
9.93 @ 132 Charles Myers, Plymouth Arrow, 6/21/2003
9.97 @ ??? Cox Bros, 66 Dart
***10 Second Zone***
10.19 @ 129 Mike Jeffrey and Blaine Mueller's "Buzzin' Half Duzzin' 1968 Valiant
10.5 @ 127 Will 67 Barracuda methonal & nitrous with Cam2 enrichment July 2004
10.74 @ 127.47 - 1.57 60', turbo66valiant, 66 Valiant Signet, 2800# w/o driver, turbo, intercooled, 727, 2.94, AV gas, July '10
10.77 @ 120.13 Team Green Lancer on alcohol, MoKan 18 March 2017
***11 Second Zone***
11.02 @ 120.56 Shaker223, 1.57 60', Turbo/FMIC, 1970 Swinger, 2.76 gear, 255/60/15 radials, 3300lbs Race Wt. Sept 2010
11.14 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
11.363 @ 114.47, Exner Geek, 62 Valaint, 150# lighter than Guzzi, 904, 4.56, Webers, on gas at Cedar Falls, IA 10/16/10
11.436 @ 115.51 mph at A Gas weight, Guzzi Mark 7/16/2011, Samoa Dragstrip
11.500 @ 117.725 MPH (not correct) (NEW B GAS RECORD) Sacramento Guzzi Mark 9-12-2010
11.54 Dave Mueller Alchohol Injected (C/Alcohol Record)
11..65 @ 114.5 Nick Stamm (turboram) 3700# 86 ram turbo NO2 to launch
11.77 @ 116.29 Shaker223, 1.83 60', Stock Slant 6 with turbo, 1970 Swinger, 2.76 gear, 215/75R/14 radials, 3500lbs Oct 2009(retired)
11.893 Ron Hamby at Clay City, KY 2011 '66 Dart on Alcohol
***12 Second Zone***
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 107mph Ron Hamby at ClayCity Ky. 2008 '66 Dart on Alky---
12.30 @106. 1.63 60' Andrew Howard @ samoa aug 2014
12.33 @ 107.88, Samoa, SwinginSixAric
12.424 @ 101.67, Old6rodder, "Flyin' Brick II", Dragfest '18, Famoso
12.43 @ 102 mph at Clay City 10- 10- 09 Ron Parker
12.64 @ 105, Doctor Dodge - 62 Lancer, Sacramento 2010
12.77 @ 104 Andrew Howard,62 Valiant (Mr.Loud) Sacramento, CA.2010
12.905 @ 101.85 mph Charlie Schmid 66 Cuda 170 nitrous
12.941 @ 105.50, Old6rodder, HA/GR "Barn Job #18", ANRA finals '09 (car retired)
12.98 @ 101.03 at Redding, "Wayne's World" 170 cu inch (on gas) 62' Valiant -Wayne Erickson-
***13 Second Zone***
13.01 @ 101.24 PJ Jesiolowski Sacramento Raceway 11 March 2013
13.105 @ 103 MPH, Lou Madsen, '68 Dart 270, 200-4R trans w/2600 stall, 3.55 8.75", 245/45-16 Pirelli Trofeo R tires, 14 psi boost, 3250 racewt, Hagerstown race 5/19/17 (89 deg F), drove there'n'back
13.39 @ 96 sgtmcd42, Crooked 6, red light lifted @ 1000'
13.41 @96.76 Rick Covalt Big Bore II- 2800# - Mason Dixon 5/2017
13.41 @ 96.20 Charrlie Schmid, 66 Valiant 225cid
13.47 @ 99.9, Stan Aiton (hyper_pak), 67 Barracuda Coupe 4 speed, 3,000#, Richmond Dragway in 1988
13.58 @ 99.46, 1.82 60', 8.63 1/8 mile, Exner Geek, 62 Valiant, Street Driven, 2800#, A833OD 3.73 gas, May 2011
13.74 @ 94.7, Lou Madsen (Dart270), autoX tires, 904, 3.25 rear, 2670 lb racewt - Project V - Clay City Race 10/08/10
13.749 @ 93.431 - Rob Simmons, '73 "GodsRods" Duster, 07 Oct 12 @ Clay City
13:82 @ 99.8-The Little Red Piggie- Motor only-RT 66- 8-7-11
13.82 @ 94.97, Rick Covalt- 65 Valiant, 1.86 60', 2800#, 3.91 Auto, 6100 RPM, Mason Dixon , all motor. 5/18/13
13.95 @ 97.1 - Lou Madsen, 64 Dart, as street driven, pump premium, 225/45-17 Goodyear Eagle F1, 2910# racewt, M-D race 5/18/14, 13.99 @ 98.72 MPH at Woodburn, Aug 2015.
***14 Second Zone***
14.061 @ 96.58 Ryan Covalt '72 swinger daily driver 3330# (50 shot) Mason Dixon 7/30/2010
14.15 @ 91.02 Crazy Dart (converted from 1/8mi) 67 Dart,904, 3500 stall, 4.30 gear. 5500 RPM.
14.206 @ 94.76mph 2.05 60' METALSKIN draw thru turbo slant (9psi) AP5 valiant 2.9
14.25 @ 91.5mph 1.91 60' 235ci, 904TF/3500 4.86's 68 SS Dart 805moparkid
14.30 @ 96 MPH Lou Madsen '64 Dart 270 in street/strip trim in 1997 at Pomona Dragway (904w/3400 stall, 14" Radial TAs, 60 over cast pistons)
14.671 @ 92.62 Ceej in the Hooptie, Samoa 11 July 2015
14.743 @ 89.81, 1.931 60' Bren67Cuda904, 258 ci Slant (Eileen) 3400 lbs with A/C, Gear Vendors, Full interior including Child car seat, 8 1/4, 3.55
14.79 @ 93.56 Greg Ondayko
14.84 @ 91.22 Ryan Covalt 72 Swinger 3330# Daily Driver/ Mason Dixon May 31,2009 4.30's, 4 sp.OD no nitrous
14.937 @ 89.74 mph "6 Pac To Go" Fopar's Mopar '63 Dart GT/stock convertor Woodburn 8/13/11
14.94 @ 87.70, Rick Covalt- 65 Valiant, 1.98 60', 2800#, 3.91 Auto, 5200 RPM, 225-re-ring, .473 lift, 2 barrel, Mason Dixon, 10/9/16
***15 Second Zone***
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 BB converter
15.20 @89 Joel Harris 69 Valiant, 225 stock bottom end, .100 off head, 2bbl, pump gas, mopar268 cam, headers, stall, 3.91, 904, 2750# w/o driver, mostly stock driver
15.34 @ ?? Brian '74 Duster,1971 225 block ,.100 off blk, .100 off head,MP 528" lift cam with 284 duration, 904,4.10
15.39 @ 87.32 Fopar May/4/08 3400lb 53 Ford 225 bored .030 .090 off head custom cam custom headers 904/4.11's
15.39 @ 87.7, Lou Madsen (Dart270) '90 Slantkota with 258" engine, mild cam, 3.23 gear, 2400 stall, 3310 racewt, Clay City Race 10/09/10
15.40 @ 89 mph Lindross, roadster
15.501 @ 88.32, SV162, low comp head, 3.7 diff, May 2008
15.73 @ 88.32, SV162, high comp head, 2.92 diff, Sept 2009
15.6 @ 90 MPH - '68 Dart street car - Lou Madsen - 1996 at LA Cty Raceway
15.82 @ 84.32 1974Duster Kev- Converted from 1/8 mile numbers
15.85 @ 87 - GodsRods Duster I @ SGMP in May 2006, 2,850# w/driver
15.9 @ 85 classic ap6 from oz, 3.23, may 2012
***16 Second Zone***
16.18 @ 84.26, SV162, low comp head, 2.92 diff, Feb 2009
16.281 @ 82.64 DusterIdiot, Medford, Hpak Duster Holley Annular 600, 3400 lbs
16.35 @ 81.3 70valiant', 3.23
16.59 at 81.68mph TRYSIX '65 Coronet 4dr, Isky cam 228/448
16.707 @ 82.11 Mike Andreas,225 cid block +30. Stock pistons .100 off the deck. Isky 448 lift, 4 speed
16.868, 80.06 MPH J. Skinner '67 Valiant 100 3-speed, stock short block
16.89 @ 78.49 3.23open 75 duster (Wicked/six)
***17 Second Zone***
17.03 @81 MPH. Casey Reed R688 '70 Dart 225/904, 4-BBL, headers. 2.76 open.
17.13 @ 77.30 aaron downing 225, 904, 4-BBL, headers, 390 holley, 3:55 suregrip
17.20 @ 85 The Black Sheep
17.27 @ 79.03 Featherduster76(converted from 1/8mi) 71 Duster 225/904
17.29 @ 78.66 Rhonda Amis '66 Valiant Signet 200 225ci,904 MATS 2009
17.44@78 Slant Cecil '68 Signet 225, 904 ,2975lb w/driver ,140K mile motor with 6x1 header, BBD, electronic ign ,4400rpm shift
17.55 @ 76 Rick Covalt 85 D100 tow/race truck, 225/904/3.55 rear. .437 lift cam/ 4barrel/ header, 3720# , 1st run & tow
17.69 @ 75.78 THOR 65 Dart GT "Madeline"
17.72 @ 77 Nick Bowman 1970 Plymouth Duster 2bbl-904-3.23
17.73 @ 75.89 Mike Bjerklund 1968 Dart 4dr 1bbl-904-3.23 Woodburn 7 Jul 12
17.88 @ 77 Allen Dutra 66 Dart Station Wagon "tow car" 1 bbl 260 stroker w/ 3.23
***18 Second Zone***
18.281 @ 72.99 Mike'68Dart, Sept 10, 2011
18.312 @ 72.31 Vallyant
18.705 @ 73.41 The Hard Way '74 Dart 4 Door 198 Auto
18.763 @ 72.26 66 Dart GT Convertable, Super six, HEI, 3.23, 904
18.766 @ 70.69 Mike'68Dart, Aug 28, 2009
18.788 @ 71.35 Chase Simmons '74 Duster, Woodburn, OR 23 June 2012
18.832 @ 72.82 Dodgegirl
***19 Second Zone***
19.05 @ 73 Davids63Dart, September 2007
19.21 @ 70 Doc, 65 Dart GT Convertible, stock alm block 225 ,1bbl
Carter, Dutra dual exhaust, 904 auto. trans., 2.94 8 3/4 rearend.
19.26@68 77Volare Wagon, stock, supersix, 833-od
19.35 @ 69.85 THOR, '74 Swinger, Redding Dragstrip (Stock Cast crank-juice engine... stock 2.76:1 "SG") 10/25/08
19.37 @ 69.77 Aggressive Ted, '74 Swinger, Pacific Raceways
19.52 @ 69.26 Slanted66, Altitude 5300 ft (Headers, Isky cam, 1bbl, 904, 3.23s)
19.6 @ 71 eightymopar , 1980 Cordoba
19.78 @69.56 1980volare, 1980 volare,bbd 2.76,28" tires,stock exhaust.
19.99 @ ???? ryguytoodry 1965 Belvedere II Four Door, Stock Slant, 3600#,
Mom Driving.
***20 second Zone***
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out
Author:  Dart270 [ Tue Sep 11, 2018 1:47 pm ]
***9 Second Zone***
12.756 @ 107.452 MPH, Lou Madsen, '68 Dart 270, 200-4R trans w/2600 stall, 3.55 8.75", 275/50-15 M/T drag radials, 14 psi boost, 3270 racewt, Clay City race 9/10/17, drove there'n'back (D/U records for ET and MPH)
13.611 @ 95.833, Lou Madsen (Dart270), 235/60-15 Goodyear drag radials, 904, 3.80 rear, 2660 lb racewt - Project V - Clay City 20th Reunion Race 9/7/18
Mom Driving.
Author:  slantzilla [ Sat Oct 27, 2018 1:01 am ]
***9 Second Zone***
13:05@103 Slantzilla US 41 "Buzzin' Half Duzzin'" Valiant 235 ci pump gas junk
Mom Driving.
Author:  Rick Covalt [ Tue Oct 15, 2019 4:46 pm ]
***9 Second Zone***
12.80 @102.88,Rick Covalt, 65 Valiant, Big Bore III, 2775#, 4.30 gears, Webers, Mason Dixon 5/16/21 -All motor
Mom Driving.
Author:  Dart270 [ Wed Oct 16, 2019 5:45 am ]
***9 Second Zone***
12.811 @ 102.13, Lou Madsen (Dart270), 255/60-15 M/T drag radials, 904, 3.80 rear, 2700 lb racewt, 77 shot of N2O, misfiring like stink - Project V - Mason Dixon Race 10/14/2019
12.95 @100.6,Rick Covalt, 65 Valiant, Big Bore III, 2800#, 4.30 gears, Webers, Mason Dixon 10/13/2019 -All motor
13.589 @ 96.13, Lou Madsen (Dart270), 255/60-15 M/T drag radials, 904, 3.80 rear, 2700 lb racewt, on the motor - Project V - Mason Dixon Race 10/14/2019
Mom Driving.
Author:  Rick Covalt [ Sun Jul 26, 2020 11:56 am ]
***9 Second Zone***
12.84 @101.99,Rick Covalt, 65 Valiant, Big Bore III, 2775#, 4.30 gears, Webers, Mason Dixon 7/24/20-All motor
Mom Driving.
"You mean you still have a Slant 6 in that thing?"
Author:  Not2slow [ Mon Sep 21, 2020 5:51 am ]
I made a banzai run at Tulsa this last Friday (9/18/20) and put the #43 Go-Dad-Go SDRA Dragster into the 10's. This is naturally aspirated with 112 octane gas. :lol:
I followed that up with another sub 11 run. Larry (#1 Running the 4.0 Jeep) and I were out of the running, so we both decided to give it all we had. He ran a little better than I did, but remember, he has a few more inches than I do.
Author:  Old6rodder [ Mon Sep 21, 2020 9:46 am ]
***9 Second Zone***
10.971 @ 118.34, Not2slow, SDRA HAMBster, Tulsa, 9/19/20
Mom Driving.
Author:  Rick Covalt [ Sun May 16, 2021 5:40 pm ]
***9 Second Zone***
12.80 @102.88,Rick Covalt, 65 Valiant, Big Bore III, 2775#, 4.30 gears, Webers, Mason Dixon 5/16/21-All motor
Mom Driving.
Author:  Not2slow [ Wed Jun 16, 2021 7:04 am ]
***9 Second Zone***
10.500 @ 123.62, Not2slow, SDRA Dragster, Thunder Valley, Noble OK, 6/12/2021 (NA Race Gas) 1.482 60'
Mom Driving.
Author:  Not2slow [ Mon Jul 19, 2021 1:20 pm ]
***9 Second Zone***
10.271 @ 122.85, Not2slow, SDRA Dragster, MoKan Dragway, 6/17/2023 (NA, 112 Gas) 1.396 60'
Mom Driving.
Author:  Rick Covalt [ Sun Aug 20, 2023 6:16 am ]
***9 Second Zone***
12.70@ 104.58 Rick Covalt, 65 Valiant,4.30's,Webers (40MM Venturis),Mason Dixon 8-18-23, 2825#
12.80 @102.88,Rick Covalt, 65 Valiant, Big Bore III, 4.30 gears, Webers, Mason Dixon 5/16/21-All motor
Mom Driving.
Author:  Not2slow [ Tue Jul 30, 2024 10:33 am ]
***9 Second Zone***
10.132 @ 127.77, Not2slow, SDRA Dragster, MoKan Dragway, 7/26/2024 (NA, Methanol)
Mom Driving.
Author:  Rob Simmons [ Tue Sep 03, 2024 6:47 am ]
***9 Second Zone***
11.399 @ 115.952 Rob Simmons '81 Challenger on methanol, 2,338 lbs Kentucky Dragway 31 August 2024
Mom Driving.
Author:  hyper_pak [ Thu Mar 26, 2026 5:02 pm ]
***9 Second Zone***
13.29 @ 107.7, Stan Aiton (Hyper_Pak), Tulsa Raceway Nov 2024, 2250 Lbbs.'72 Dodge Colt Gas.
Mom Driving.
Page 12 of 12 All times are UTC-07:00
