| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 124 of 128 |
| Author: | slantzilla [ Wed Jan 08, 2025 8:20 am ] |
| Post subject: | Re: Covalt - "Project 65 Valiant" |
Should be. |
| Author: | Rick Covalt [ Wed Jan 08, 2025 9:33 am ] |
Quote: Should be. Hmmm? Should I trust you? You may be trying to make me run slower so when we meet up you don't get flogglewhomped! |
| Author: | Rob Simmons [ Wed Jan 08, 2025 9:35 am ] |
Quote: Quote: Should be. flogglewhomped!
| Author: | Dart270 [ Wed Jan 08, 2025 12:02 pm ] |
Good to know it was that big of a change. It may not make the car faster overall, but it will make the low/midrange and idle better. May not matter depending on your converter stall. 0.032" should not hurt it. Lou |
| Author: | Rick Covalt [ Wed Jan 08, 2025 1:39 pm ] |
Quote: May not matter depending on your converter stall.
Andre (Edge) built mine for 4000.
| Author: | slantzilla [ Wed Jan 08, 2025 8:18 pm ] |
Quote: Quote: Should be. Hmmm? Should I trust you? You may be trying to make me run slower so when we meet up you don't get flogglewhomped! I've already been low .70s. Don't sing it, bring it. |
| Author: | Rick Covalt [ Tue Mar 18, 2025 5:43 pm ] |
I drove the car to work a day last week and it feels soooo good! I can't believe how it pulls. Oops! I forgot I still have the 4.89 gears in it from last fall at Knoxville. |
| Author: | Greg Ondayko [ Wed Mar 19, 2025 6:28 am ] |
Your 2 Mile Jaunt from Buttermik to Quincy should be fun! I think there should be some TNT's at Mason Dixon soon? what about Quarter Aces Drag -o- Way? you should be able to get up there before easter. Best of Luck, and See you in May! Greg |
| Author: | slantzilla [ Thu Mar 20, 2025 11:54 am ] |
I've been 8.02 with 4.86 gears. I think with some tuning I can get to 7.80s. |
| Author: | Greg Ondayko [ Mon May 05, 2025 5:29 pm ] |
Well, whatwusit? |
| Author: | Rick Covalt [ Mon May 05, 2025 6:20 pm ] |
You have to give a guy time! I was eating a bowl of ice cream! Attachment: IMG_0167.jpg [ 52.64 KiB | Viewed 11095 times ] Car had 4.56 gears in it so I knew the mph would be off a little. Plus the weather was about 100% rain in the air all afternoon Car ran: 13:01 / 101.03 ----------13.01 / 101.28 ----------13.03 / 101.40 ----------13.07 / 101.58 |
| Author: | Dart270 [ Tue May 06, 2025 4:40 am ] |
Glad to hear it was simple! Are those factory adjuster screws? Hard to see. If so, you might need shorter pushrods. Lou |
| Author: | Greg Ondayko [ Tue May 06, 2025 5:07 am ] |
Quick Fix! Great. I thought it would be something simple as you kind of thought, as when you pulled it up on the trailer it did not sound catastrophic to me. Lou, Rick swapped out to non stock adjuster screws, so the locknut/ jamnut is required. Greg |
| Author: | Dart270 [ Tue May 06, 2025 6:03 am ] |
Gotcha. |
| Author: | Rick Covalt [ Fri Oct 31, 2025 8:26 am ] |
With the demise of our racing series, I have decided to remove the noisey Carter electric fuel pump so I can run the car on the street and still hear myself think. Dan gave us a nice way to get a high volume low pressure fuel pump but that involved a lot of extra work and special parts....etc. Since all the new slant 6 fuel pumps are basically made of tin foil, I purchased a old AC fuel pump for a 1966 engine. Part #6972. It is obviously built twice as strong as the new junk! So I thought I would bolt it on and try it first and see just how it worked. And since I have a fuel pressure regulator on the car already it was worth a try. I bought a couple AN fittings to bypass around the rear mounted electric pump ( I left it in place) and then mounted the new fuel pump and filter up front and tied into my existing fuel line. Fired everything up and it sat there and ran with 3.75# and never waivered. I ran it up to 4000 rpm and things were still rock solid. I took it out for a run and ran it up to 6300 rpm and it never missed a beat. So I think this old "stock" fuel pump will be just fine. Next up will be to get the full exhaust system installed out the back. Already have the Magna Flow mounted and it sounds much better than what I had on it. More to come. |
| Page 124 of 128 | All times are UTC-07:00 |
