| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 125 of 128 |
| Author: | slantzilla [ Fri Oct 31, 2025 8:50 am ] |
| Post subject: | Re: Covalt - "Project 65 Valiant" |
Thanks for the update Rick. On the fuel pump, sometimes we get lost on the need for the latest, greatest pieces just because we believe we need them and they look cool. Years ago a buddy raced a 427/4 speed Fairlane and was running low 12s with a stock fuel pump and lines. Everybody told him his pump was holding the car back and he needed an electric pump and all the goodies that went with it. He spent almost $200 for the pump, all new bigger lines, and regulator. Guess how much the car picked up? 0 |
| Author: | Rick Covalt [ Fri Oct 31, 2025 9:05 am ] |
Quote: Guess how much the car picked up?
I bet he ran 10's! |
| Author: | slantzilla [ Fri Oct 31, 2025 10:30 am ] |
| Author: | Greg Ondayko [ Fri Oct 31, 2025 2:05 pm ] |
I ran a stock Slant 6 pump on Ruster for many years with a 750 Carb it went 12's. |
| Author: | Rick Covalt [ Fri Oct 31, 2025 2:09 pm ] |
Yep! The webers want high volume and low pressure, @ 3.5# or so, thus my concern that the stock pump may have too much pressure and then drop off at high rpm. Doesn't appear to be an issue. |
| Author: | Greg Ondayko [ Fri Oct 31, 2025 3:52 pm ] |
Oops. Forgot about webers.. Yes you wants something non stock. Greg |
| Author: | Rick Covalt [ Fri Jan 23, 2026 7:58 am ] |
Most all of the parts are now on hand or are on the truck shipping from Dr.Diff to perform my 4 speed swap! New "modified" Quick time bellhousing- check Lightweight steel racing flywheel, resurfaced-check New Mcleod 10 1/2" clucth and PP. - check Mcleod Hydraulic clutch assembly - check Measurement from Lou on hydraulic clutch rod mount-check ( Wonder where I put that?) Rebuilt 833 OD with new shift fork & linkage-check Offset master cylinder adapter-check Two cans of color matched paint for the inner fenders-check New front and rear carpet-check New shifter boot-check New Rod & main bearings-check (These are just in case I want to pull the pan while engine is out, which I likely won't) New complete fuse box & wiring-check ( If I am feeling energetic, which I'm not) I don't think I am missing anything all that big. So after the Blizzard here I come! |
| Author: | Charrlie_S [ Sat Jan 24, 2026 7:42 am ] |
Go, Rick, Go |
| Author: | Rick Covalt [ Wed Feb 11, 2026 12:00 pm ] |
Finally got out of the single digits for more than 10 minutes here in PA, so I was ready to start my 4 speed install. But before I started I had something I had wanted to do for a long time. I always wanted a nice metal top on my workbench. So our local metal guy bent me a top to fit my existing table. Man do I love it! 1/8" thick and it was just a bit over $120. Here is a picture. Attachment: IMG_1123.jpg [ 28.8 KiB | Viewed 4717 times ] Attachment: IMG_1130.jpg [ 18.77 KiB | Viewed 4717 times ] Attachment: IMG_1128.jpg [ 16.67 KiB | Viewed 4717 times ] After talking to my friend who built the bottom end for me, I have decided to cut the oil filter apart and look at the evidence. If it looks good then I am not going to pull the pan off at all. Since I have not had any problems and no drop in performance he said he wouldn't touch it unless the filter says differently. Made sense to me! |
| Author: | Rick Covalt [ Thu Feb 12, 2026 2:19 pm ] |
Engine and transmission is out and separated from each other. Removed the automatic shifter and cable from the car. Removed everything from the inner fenders and unbolted the master cylinder. Test fit the new offset master cylinder bracket- All looks good. I mounted the blow proof and checked the run out and it is dead on left to right and out about .004 up and down. I can't remember the tolerance but I think that is close enough. I have to get an input bushing in the morning since my crank has none. I am doubtful the blowproof will fit my early A body without some massaging on the tunnel. Mainly because of the way the top two bolts go in. I will likely cut a window in the floor board to access those two from the inside. Pictures to come tomorrow. |
| Author: | Rick Covalt [ Sat Feb 14, 2026 11:40 am ] | ||
| Post subject: | Re: Covalt - "Project 65 Valiant" | ||
Mounted the block plate and flywheel with lock ring. Installed new pilot bushing. Test fit the starter since this blowproof had the starter mount moved out @ .400" so I can run the V-8 flywheel and clutch. Engagement looked great. Mounted the clutch , Pressure plate and then installed the blowproof. Now I will stick this in without the trans so I can see how much I need to massage he floor pan / firewall area. If it is too much I will just cut out a large window and make a new plate for over it. Not like this is a show car! Attachment: clutch.jpeg [ 47.97 KiB | Viewed 3705 times ] Attachment: starter teeth.jpeg [ 23.72 KiB | Viewed 3705 times ] Attachment: header clearance.jpeg [ 41.31 KiB | Viewed 3705 times ]
| Author: | Greg Ondayko [ Sat Feb 14, 2026 3:47 pm ] |
No clearance issues with your headers? Greg |
| Author: | Rick Covalt [ Sat Feb 14, 2026 7:50 pm ] |
No actually. The bellhousing clears the headers by about 2" and I am running the hydraulic clutch setup, so no Z bar. Attachment: header clearance.jpeg [ 41.31 KiB | Viewed 3747 times ] I sat the engine down in the car with the bellhousing on and it fits pretty well. It was touching or very close on the top most bell bolt. So I marked that area (The whole way around the top of the bellhousing) and then took the hot wrench and a small dead blow hammer and "massages the area back about an inch. Also heated the pinch weld and rolled it up flat just to be sure. More to come. Here you can see the bolts at the top and right hand side. They are actually about 2 1/2" long and have a welded tube into the blow proof. This actually makes the bellhousing quite a bit deeper towards the firewall in those areas. Attachment: blow proof.jpeg [ 45.64 KiB | Viewed 3745 times ] |
| Author: | slantzilla [ Sun Feb 15, 2026 12:21 pm ] |
Great stuff Rick! |
| Author: | Rick Covalt [ Fri Feb 20, 2026 11:37 am ] |
With the engine out I had always wanted to repaint the inner fenders and firewall to match the outside of the car. It is a dirty rotten stinkin job as my dad used to say! Also sat the engine back in (3rd time) and verified how it will sit on factory mounts. I saw that my K-frame on the passenger side at the oil pan was all but touching. So I pulled the engine back out cut another piece out of the K frame and welded in a plate that was back about another 3/4" for extra clearance. Mounted the clutch master on an aluminum plate I made, that sat in beside where the steering wheel goes through the firewall. After 2 hours of fiddling I realized it was too far down on the pedal and I would only have about 2" of pedal travel. Not going to like that. Started over and ended up mounting the master through old speedometer hole. Looked just about right! I made a Z-shaped bracket and welded it to the original clutch pedal so it lined up on the center of the master. Mounted everything including the offset Brake master cylinder and everything looks good. Probably 4 1/2" of pedal travel now. After carpet padding is in I will bolt in a pedal stop so as not to bottom out the master cylinder. I made a small stiffener plate for inside the car behind the master, but I will fabricate a nice bracket to go from the inner fender back to the master cylinder.That will take out all flex in the firewall. More to come. Attachment: clutch master.png [ 235.62 KiB | Viewed 3957 times ] Attachment: IMG_1162.png [ 208.88 KiB | Viewed 3957 times ] Attachment: IMG_1169.JPG [ 64.19 KiB | Viewed 3957 times ] Attachment: IMG_1174.JPG [ 70.48 KiB | Viewed 3957 times ] |
| Page 125 of 128 | All times are UTC-07:00 |
