It is currently Sun Nov 29, 2026 12:05 am
Post new topic  Reply to topic  [ 1934 posts ]  Go to page Previous 1 … 125 126 127 128 129 Next
PostPosted: Wed Apr 22, 2026 8:46 am
:shock: :shock: :shock: :shock: :shock:
Here I think pulling the pan on my 904 to change the bleed off orifice for the brake sucks......
PostPosted: Mon Apr 27, 2026 11:46 am
I will put a post out in the transmission section about this.
PostPosted: Sat May 09, 2026 7:38 pm
Here is the final update of the transmission issues I was having with the 4 speed install. 1st part is in this link.https://www.slantsix.org/forum/viewtopic.php?t=68620
After the last post in that link I went ahead and pulled the transmission back out and got the second identical 833 OD from Ryan. Before I installed it I removed the side cover and checked the shift interlock levers and looked for anything amiss inside this 2nd transmission. I saw nothing and the truth is that both of these transmission were run and were fine in Ryan's Dart. So I went ahead with the install, which is really no fun. But I had high hopes we would be good to go. Unfortunately this tranny acted exactly the same as the first one! N0, I'm not kidding. So after doing everything right that I know how to do on this install, and still having issues, I made the executive decision to swap the automatic back in. Yeah I know! I don't give up easily, but I think I have just run out of steam as far as fighting this any more. At 65 years old I am just too old to be this frustrated with something that is supposed to fun to do. So this past Thursday night and all day Friday I reinstalled a nice automatic and 4000 stall speed convertor. I had to reinstall the oil cooler and the automatic shifter assembly too. Fired it up and ran it down the road just like it was never removed! At least now I can go race with it.
As I contemplate what could be going on, I would have to guess something in the hydraulic clutch set up but I don't know what. No grinding when shifting. Going from 1st to reverse rather quickly without grinding says the clutch is releasing properly.(At least that is what Brewers says) So since I can't make sense of it, I will be driving an automatic for the foreseeable future.
The truth of the matter is I wanted the 4 speed for the OD, but I think I will likely just let the 4.30 gears in for racing and then swap in some 3.55 to run it on the road. Or maybe even a new set of 3.73's would be a decent compromise. I have a bad knee that will need replaced some day so I may not be able to push in the clutch anyway. Yes, I am trying to talk myself into being happy. But after several months of work, with many many changes and upgrades, I never figured I'd be back to an automatic.
PostPosted: Sun May 10, 2026 4:41 am
Last thing I can think of is that the Hydraulic cylinder is extending too far pushing the fingers into the springs of the clutch disc. Maybe a clutch pedal stop in the floor is needed (experiment by shifting by pushing clutch less)?
Good deal on automatic for now.
PostPosted: Sun May 10, 2026 7:52 am
Too soon?
PostPosted: Sun May 10, 2026 10:57 am
It was either an automatic or set the garage on fire. I debated for a while .... :D :D
PostPosted: Mon May 11, 2026 7:48 am
Rick,
Man, that sucks. I have been there and sometimes you do want to set everything on fire. But, eventually (usually) we regain our patience and figure things out. Otherwise, just make the car work again and enjoy driving that suckah!
The one other thought I have is maybe the pilot bearing/bushing is binding on the input shaft? I guess you dial indicated the BH, so it *shouldn't* be an alignment/angular issue?
Hope to see you at M-D in a week!
PostPosted: Mon May 11, 2026 7:49 am
Hm. If you really want to clutch dump a Slant 6 car, you and I could trade cars on Sunday! I'll be bringing the 62 Valiant with slicks and everything...
PostPosted: Mon May 11, 2026 1:28 pm
Rick I forget, why didn't you use stock Z Bar stuff?
PostPosted: Mon May 11, 2026 1:41 pm
Early A body and long tube headers. The Z Bar does fit but I picked up the entire Mcleod hydraulic clutch system for cheap and figured that would free up a lot of room and lots of people have used that system without issue. Looking back, the Z Bar setup is probably what I should have used.
PostPosted: Tue May 12, 2026 8:51 am
Too soon?
Says the guy who has his transmission held in with Dzus fasteners...... :lol: :lol: :lol: :lol: :lol:
PostPosted: Tue May 12, 2026 2:21 pm
Too soon?
Velcro.
PostPosted: Wed May 13, 2026 7:19 am
Velcro.
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: Mon Nov 02, 2026 11:09 am
Clay City Update.
I never did post anything about the trip to clay city and how things went. I will say my main concern on a 18 hr roundtrip for me was not the race car but my 25 year old, 210,00 mile Tahoe. But that part of the trip was flawless. No problems at all.
We arrived about 3:30PM and met up with a bunch of the guys. It was good to see everyone at a race again! Andrew Shank and I unloaded and we were ready to go. I took the car up for the 1st time run and it clicked of a 12.96 @ 100.2 right off the truck. That was good considering the air we had (90 and humid) and I was pleased with that. I went back up 8 minutes later and ran another pass and this time the car seemed Ok, but when I got the time slip it had ran a 13.8 at @93.6! Wow something was wrong! .9 & over 6 mph off. So I checked the timing and it was fine. Checked to verify the throttle was fully opening the butterflies and that was fine too. Fuel pressure was @ 3.75# and seemed fine but I did bump it up about 1/2# just in case I was a little fuel starved. Then we got rained on and we called it a night
Saturday I looked things over again and didn't really see anything obviously wrong. All the 1/4 miles runs Saturday were bad. 13.87, 13.68,13.65, 13.50. These 4 runs were all about 20-30 minutes apart. This all seemed odd to me because there was no misfire or fluttering or anything to indicate an issue. It was just slow. On one of these runs I thought I smelled a burnt wire smell on the return lane. But I didn't know if it was my car or not, and it was only for a brief moment.
Then we had @ 1hour break and went to our 1/8th mile runs. 1st run in the 1/8 was really good. It ran 8.08 @ 83mph which according to all my past records would have been a 12.80 run. 20 minutes later it ran a 8.24, off 2 1/2 tenths! The 3rd run, I was given the wrong time slip so I don't know what it did. But the last run on the night we did have a little longer time between our runs due to some breakage. So the car was cooled down well. Run 4 was the best of the weekend 8.02 @ 84mph which was was really close to the all time best.
One thing I did notice after thinking about the burnt smell was that the MSD housing that held my HEI modules was very hot. I hid two modules up inside a empty housing and wired it all up neat and clean. It looked good but I was wondering if the modules were getting to hot and not working properly. I did place my fan on the engine before that last run to cool down the MSD housing good before my run. I really don't know what is going on.
After I got home I decided to remove the HEI / MSD housing and just remount the HEI modules on a new aluminum plate. Then I figured I'd take it to Mason Dixon and see if that fixed it. After another week or two, I went out on a Friday morning to test run the car down the road and make sure I was ready for the dragstrip on Saturday. Car fired right up and I pulled it out of the garage and when I hit the brakes the pedal went clear to the floor! Pumped it multiple times to get enough pedal to stop me and my weekend was over before it started. I backed it off the trailer after Clay City and never touched it as far as driving it till now, and the brakes failed sitting in the garage! Go figure! I checked the fluid level and it was full. I checked all four corners for a leak and found none. Pulled the rear drums and it was dry inside. No cracked or broken hoses and no leaks inside the car at the fire wall! I am not even sure how that is posssible? But I ordered a new Master cylinder and installed it and bled the brakes and all seems well. That is just weird to me!
So here we are Nov 1st and I still have not been to the track. I'm still going to try here again in 2 weeks.
PostPosted: Mon Nov 02, 2026 11:57 am
Good luck buddy!
It was great seeing you again at CC.
My home track closed Friday night for the year. For some odd reason the county won't let them run past October 31. :oops:
