| A new bullet https://slantsix.org/forum/viewtopic.php?t=28649 |
Page 14 of 20 |
| Author: | turbo66valiant [ Mon Feb 22, 2010 7:16 pm ] |
Quote: |
| Author: | Joshie225 [ Mon Feb 22, 2010 7:37 pm ] |
Yeah, on level ground it does. Kills the approach angle though. |
| Author: | turbo66valiant [ Mon Feb 22, 2010 8:16 pm ] |
Yep, it will suck but my trailer has a low approach angle so not to worried. |
| Author: | USAJon [ Tue Feb 23, 2010 8:51 am ] |
sorry if i missed it. but what sort of RPM's through the traps. I read last night on ALLPAR back in the day a stock 170 would wine to 6500 RMP using a 3 speed and the man stated there was more to go..that's impressive in those days. |
| Author: | turbo66valiant [ Tue Feb 23, 2010 7:22 pm ] |
This one only spins at 5200. Later |
| Author: | turbo66valiant [ Sun Feb 28, 2010 8:28 pm ] |
I got a few things done today. Main studs are in, o-ringed the block, degreed cam in at 109*, checked cam and bearing wear, trimmed copper head gasket. Ready for the head and possible new exhaust. We'll see. Isky o-ring tool worked nice. ![]() ![]() ![]()
| Author: | Shaker223 [ Mon Mar 01, 2010 6:56 am ] |
Sweet! |
| Author: | Greg Ondayko [ Mon Mar 01, 2010 2:16 pm ] |
Does the iksy O ring tool Work with the pistons in place? I would imagine it would be a chore to keep the chips out of the ring pack? Lookin Good! Greg |
| Author: | Dart270 [ Mon Mar 01, 2010 2:37 pm ] |
Oily/greasy rags and vacuums are your friends. Can't tell you how many holes I've drilled and bore notches I've made with everything assembled. My favorite was drilling a new hole in a spun rear cam bearing with the motor in the car and just the head off. No problems... Lou |
| Author: | Shaker223 [ Mon Mar 01, 2010 5:10 pm ] |
A shop vac is your best friend. I did the Isly o-ring in car as well. Like Lou said....plug everything up that you can and then vac away!!!...If you have a helper they could vac while you cut away. I've port matched in the car this way too. |
| Author: | darrt wells [ Mon Mar 01, 2010 8:17 pm ] |
Sweet! I gots me a couple of questions about the pics tho. What is the black circle in the center of the pistons? What is the last picture showing, Main clearance? |
| Author: | turbo66valiant [ Mon Mar 01, 2010 9:13 pm ] |
Quote: Sweet! I gots me a couple of questions about the pics tho.
Not for certain what the machined holes are in the center of the pistons. Never seen them before on any others. They are standard TRW's. Anyone know? I guess I should have figured this out before I started using them. What is the black circle in the center of the pistons? What is the last picture showing, Main clearance? Yes to the main clearance. All four were the same. Later Ryan |
| Author: | turbo66valiant [ Wed Mar 03, 2010 8:50 pm ] |
Just a few pics of the current combo outside the car. Mocked up for pics. Later ![]()
| Author: | 66aCUDA [ Thu Mar 04, 2010 5:27 am ] |
Looks Great Ryan. Looking forward to meeting you in Kearney this year. Frank |
| Author: | 75customdart [ Thu Mar 04, 2010 5:40 am ] |
| Page 14 of 20 | All times are UTC-07:00 |
