| ProCycle's FI Turbo build https://slantsix.org/forum/viewtopic.php?t=56352 |
Page 14 of 25 |
| Author: | Reed [ Sun Jul 12, 2020 10:23 pm ] |
| Post subject: | Re: ProCycle's FI Turbo build |
This is some very impressive work. Thanks for sharing! |
| Author: | Dart270 [ Mon Jul 13, 2020 4:26 am ] |
Lovin' it.. Lou |
| Author: | Greg Ondayko [ Mon Jul 13, 2020 4:41 am ] |
Changing plugs will be the job of the passenger. This truck should be fast and have traction problems. Greg |
| Author: | ProCycle [ Mon Jul 13, 2020 7:54 am ] |
Reed, Lou, Greg, Thanks for following along. Now that the cab can be dropped in place things are getting more complicated. |
| Author: | sixinthehead [ Mon Jul 13, 2020 5:32 pm ] |
I can overlook the GM content because such fabrication skill deserves recognition. My hat (welding helmet?) is off to you |
| Author: | ProCycle [ Wed Jul 15, 2020 3:12 pm ] |
Starting to rebuild the tunnel. Using as much of the material that was removed as I can to simplify the fabrication. |
| Author: | Greg Ondayko [ Wed Jul 15, 2020 5:55 pm ] |
Nice, That's exactly what I did when the T5 when into Grüne Hölle. Greg |
| Author: | ProCycle [ Wed Jul 15, 2020 7:31 pm ] |
Quote: Nice,
It sure beats trying to shape and join a bunch of flat little pieces of sheet metal.
| Author: | ProCycle [ Thu Jul 23, 2020 7:03 pm ] |
The expensive tubular K-member I bought early on turned out to suck up way too much ground clearance. So, I chopped the offending chromoly stuff out And built my own Much better |
| Author: | Rick Covalt [ Sat Jul 25, 2020 11:41 am ] |
Wow! great work!! |
| Author: | ProCycle [ Sat Jul 25, 2020 12:58 pm ] |
Quote: Wow! great work!!
Thanks Rick!
| Author: | ProCycle [ Fri Oct 16, 2020 3:08 pm ] |
The chassis is getting close to being ready for the real motor to go in. I originally had a 6 quart truck oil pan on it but the pan hangs down too low. I decided I'd chop up a couple of car oil pans I have to make one high capacity oil pan. The way I have engine placement in the S10 frame there is nothing under the engine so why not use that space to increase the oil capacity? ![]() ![]() I suspect it's going to hold 12 quarts or so now. Overkill?
| Author: | Dart270 [ Fri Oct 16, 2020 6:04 pm ] |
Excellent work. We A-body guys are envious of the area available... Lou |
| Author: | ProCycle [ Fri Oct 16, 2020 7:44 pm ] |
Quote: Excellent work. We A-body guys are envious of the area available...
Thanks Lou,Lou I've been getting a lot of sheet metal welding practice lately. I'm still not good at it but I managed to avoid making a big mess! |
| Author: | Greg Ondayko [ Sat Oct 17, 2020 3:10 am ] |
Double drains and 2 numbers on the stamping. I like it Greg |
| Page 14 of 25 | All times are UTC-07:00 |
