| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 14 of 40 |
| Author: | Greg Ondayko [ Fri Jun 05, 2020 2:11 pm ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
Quote: Is that a front or rear setup?
Rear setup... on the 5/30/20 post. Front setup on the 6/5/20 post. Greg |
| Author: | Greg Ondayko [ Sat Jun 06, 2020 6:54 am ] |
Quote: Cool. Let me know the total wt of those brake parts when you get a chance.
Lou Total weight of one side including hubs, rotor, pads, caliper adapter, bearings, hose and hardware was 33.4# on my bathroom scale. I am not sure how accurate it is but that's what it says. Greg |
| Author: | Dart270 [ Sat Jun 06, 2020 4:06 pm ] |
Cool. I assume that's with caliper too. Lou |
| Author: | Greg Ondayko [ Sat Jun 06, 2020 4:19 pm ] |
Yep that includes 6 piston caliper |
| Author: | Greg Ondayko [ Sat Jun 06, 2020 4:32 pm ] |
| Post subject: | 6/6/20 |
6/6/20: Got it somewhat together.. Upper x member is done. Tacked some sheetmetal in the tunnel. Painted underneath. Filled the trans with fluid. Drove from the garage to home. Everything works 'cept Speedo.. that will get figured out later. Makin progress! Greg |
| Author: | Dart270 [ Sun Jun 07, 2020 2:43 am ] |
Big congrats on the first drive! Lou |
| Author: | Rick Covalt [ Sun Jun 07, 2020 4:44 am ] |
Quote: Big congrats on the first drive!
X2!! Yep that has got to feel good! You have done a lot of work in a short amount of time!
| Author: | Greg Ondayko [ Sun Jun 07, 2020 5:19 am ] |
6/7/20: After getting the clutch adjusted, I went on a 25 mile loop. Everything was good, Trans is a bit noisy but I suppose thats typical from an unknown mileage essentially junkyard T5. I can get a rebuild kit for it later or get a z spec trans at some point. Also have a few holes in the floor at this point and no interior so that can allow some noise in too. That aluminum flywheel is sweet and it seems that Falcon did a great job on the clutch and pressure plate. Greg |
| Author: | Badvert65 [ Sun Jun 07, 2020 7:18 am ] |
Awesome progress. I drove a 74 Road Runner big block, sans interior. It does make a big difference with the noise level. You are going from a sweet ride to a really sweet ride...... |
| Author: | Dart270 [ Mon Jun 08, 2020 11:20 am ] |
Excellent. I think you have your trans tail a bit higher than mine. What down angle did you get for engine/trans centerline? Lou |
| Author: | Greg Ondayko [ Mon Jun 08, 2020 12:01 pm ] |
I think it's only a degree or 2. I would actually have to double check. Greg |
| Author: | Dart270 [ Mon Jun 08, 2020 1:46 pm ] |
Stock is around 2.5 deg, IIRC. Lou |
| Author: | Greg Ondayko [ Mon Jun 08, 2020 2:02 pm ] |
I took a lot of time getting stuff like that worked out. Its super nice to do stuff like that with a 2 post and trans Jack. I don't think I would have the patience or determination to do all of that on Jack stands and creeper now. Greg |
| Author: | Dart270 [ Mon Jun 08, 2020 6:32 pm ] |
Yep, I did it on my back. Lift really makes it way easier... Lou |
| Page 14 of 40 | All times are UTC-07:00 |
