| Anatomy of a Slant 6 drag car-More updates! https://slantsix.org/forum/viewtopic.php?t=32996 |
Page 15 of 19 |
| Author: | slantzilla [ Tue Sep 22, 2015 12:46 pm ] |
Quote: Quote: It's taken me 7 years to get this far, let's not get in a hurry.
Now you sound like me. Well, maybe not quite as bad. But in 23 years you will be as slow as me. Rick Greg, it's a pig block Dodge. Shifter is here, very sweet looking piece. Also started getting fuel line pieces. My butt hurts. |
| Author: | wvenable [ Wed Sep 23, 2015 2:25 am ] |
| Author: | slantzilla [ Sun Oct 04, 2015 4:11 pm ] |
Went to the shop today to play with the Daytona. Started routing the fuel line and found out the place I wanted to mount the regulator will not work. Found a new place for it and will finish it all up next time. Also, set my shifter in the place on the tunnel I wanted it and it is way too close to the seat to be remotely comfortable to use. Oh well, that has to wait until I am ready to put the rest of the tunnel in. Little by little. At least I am staying past the point where I want to cut it up for scrap. |
| Author: | Dart270 [ Sun Oct 04, 2015 7:47 pm ] |
Progress forward... This is how great cars come together. Glad you are getting into it! Lou |
| Author: | slantzilla [ Mon Oct 12, 2015 8:40 am ] |
Fuel lines are done. On to the cooling system. I will be using a remote pump. Need to pull the motor plate back out and drill/tap it for the inlet fitting. Also need to try to get the bypass fitting out of the head to plug it. If I can get the plug out without pulling the head, I will also start putting on the intake/headers. |
| Author: | Dart270 [ Mon Oct 12, 2015 11:54 am ] |
chug, chug, chug, Chug, Chug, CHug, CHug, CHUg, CHUG, CHUG CHUG CHUG!!! Lou |
| Author: | sandy in BC [ Mon Oct 12, 2015 3:00 pm ] |
........these things do take time. Think Antique Drags.... Nice to see forward momentum. |
| Author: | slantzilla [ Tue Oct 20, 2015 9:00 am ] |
Got a little more done Sunday. Driveshaft, converter bolts, starter, and trans dipstick are in. Picked up a filter yesterday, next weekend the deep pan and shift linkage go on. Also picked up a water neck for a Neon yesterday. The top of the head will be higher than the radiator, so rather than try to figure out how to get the radiator high enough and still be able to get the hood on, I got a Neon water neck with a filler cap on it. I will have to make a plate to bolt to the head to adapt it since the bolt pattern is clocked the wrong way, but a trip to McMaster-Carr's website has a piece of 1/2" aluminum on the way. Ordered my water pump too. I will be using a remote setup that is an electric pump for the rear heater in a '00-02 Durango. Took time out Sunday to install a new trailer plug on the black truck. I can hook up to my trailer now without having to use an adapter. |
| Author: | DadTruck [ Tue Oct 20, 2015 12:21 pm ] |
progress |
| Author: | Rob Simmons [ Wed Oct 21, 2015 3:35 am ] |
Quote: ...on the black truck.
What black truck? What's the latest with the turd..? |
| Author: | slantzilla [ Wed Oct 21, 2015 6:56 am ] |
The Turd has been "retired" to toy status for now. The 340 in it will be coming out to go in the 340 car and the 383 I have laying around will go in. |
| Author: | Rob Simmons [ Wed Oct 21, 2015 8:09 am ] |
So where did the black truck come from? You got rid of that obnoxious yellow one... |
| Author: | slantzilla [ Wed Oct 21, 2015 8:39 am ] |
Yellow truck got traded on the SRT-8 Challenger that got traded on the Dart. Black truck is a '95 Ram 1500 that I actually bought for a buddy, but he bailed out and stuck me with it so I plated it and kept it. |
| Author: | Rob Simmons [ Wed Oct 21, 2015 1:46 pm ] |
I remembered the chain of events on the /Dakota/Challenger/Dart... Just didn't remember the '95 Ram addition. |
| Author: | slantzilla [ Wed Oct 21, 2015 3:37 pm ] |
Try to keep up, ok? |
| Page 15 of 19 | All times are UTC-07:00 |
