| Billet Aluminum Slant 6 Head! Seriously!! https://slantsix.org/forum/viewtopic.php?t=47607 |
Page 15 of 18 |
| Author: | Joshie225 [ Thu Dec 31, 2020 5:22 pm ] |
| Post subject: | Re: Billet Aluminum Slant 6 Head! Seriously!! |
Quote: Robert's head pictures.
That's really the chamber shape he wants? |
| Author: | Tim Keith [ Fri Jan 01, 2021 3:33 am ] |
Quote: I don't think making a head is that tough...it's a lot of machining but not tough.
I don't think this one will have water, but we shall soon see! The similar-to-OEM head I thought might work is a "fat head" with raised intake ports and water box on the driver side - cross drilled and welded. I'm glad Mr Maw is making progress.
Except for one thing....water jackets. Those are internal while the rest of the head is external. So the challenge in making a head, or welding up an adapted head, is getting the water jackets to not leak and to be properly placed. The beauty of casting is it allows you to make internal passages. So will his head fit? Yes. Will it run? Yes. Will it run for hours and hours with no cooling issues? That's the $64,000 question. |
| Author: | GregCon [ Fri Jan 01, 2021 6:11 am ] |
No water? Is it a drag only head? |
| Author: | slantzilla [ Fri Jan 01, 2021 11:25 am ] |
Quote: No water? Is it a drag only head?
When the project started he was going to put it on an aluminum block, not sure how drag race friendly that would be?He has also posted about doing a billet block. |
| Author: | volaredon [ Fri Jan 01, 2021 11:28 am ] |
Didn't he have plans to eventually do 3 different versions of his alum head? |
| Author: | Thomas S [ Fri Jan 01, 2021 12:30 pm ] |
Would it be possible to cast a piece of aluminum, with the water jackets from beginning ? And then machining it how you want it . Thomas |
| Author: | GregCon [ Fri Jan 01, 2021 1:45 pm ] |
Cast 50,000 heads? The first head is very expensive, the last head is almost free. Cast one head? See above. |
| Author: | Thomas S [ Fri Jan 01, 2021 4:24 pm ] |
I understand, its a lot of work /money to cast a finish head. But just to make the process more easy , just mold for the water jackets. And then cast a piece of aluminum ( with water jackets inside..) to process in the cutter. It was just a thought , |
| Author: | emsvitil [ Fri Jan 01, 2021 7:04 pm ] |
2 piece head with cooling passages between the 2 parts....................... |
| Author: | Dan-o [ Sat Jan 02, 2021 10:11 am ] |
for a cooled head, 2 piece is the way to go. Then glue it together. |
| Author: | hyper_pak [ Sat Jan 02, 2021 11:05 am ] |
Why would you want an aluminum street head?
| Author: | Killer6 [ Sat Jan 02, 2021 1:22 pm ] |
Quote: Quote: No water? Is it a drag only head?
Why would you want an aluminum street head? |
| Author: | GregCon [ Sat Jan 02, 2021 3:27 pm ] |
? Everyone alive wants aluminum street heads |
| Author: | slantzilla [ Sat Jan 02, 2021 5:07 pm ] |
Not me. |
| Author: | Rick Covalt [ Sat Jan 02, 2021 5:21 pm ] |
Quote: Why would you want an aluminum street head?
To expand the market for Ryan's MLS head gaskets!! |
| Page 15 of 18 | All times are UTC-07:00 |
