| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 15 of 40 |
| Author: | Dan-o [ Wed Jun 10, 2020 8:18 am ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
car getting a console? carpet? |
| Author: | Greg Ondayko [ Wed Jun 10, 2020 9:10 am ] |
No console. I have carpet, took out most of the interior for this install, Might have to get new carpet if this stuff does not fit tunnel Mods. Greg |
| Author: | Dart270 [ Wed Jun 10, 2020 1:31 pm ] |
I have a set of red carpet, almost new, if you want it. Uncut for the floor, so you can do what you want. Lou |
| Author: | Greg Ondayko [ Wed Jun 10, 2020 3:58 pm ] |
Hi Lou, thanks for the offer, but that red carpet would be absolutley hideous in this car. Greg |
| Author: | drgonzo [ Wed Jun 10, 2020 4:19 pm ] |
Sounds like Christmas to me. |
| Author: | Dan-o [ Thu Jun 11, 2020 8:49 am ] |
Quote: No console.
May want to fabricate a filler panel(s) to eliminate those 90* transitions. Carpet usually doesn't do too well with those. I usually end up forming a whole new tunnel so it stays smooth and covers well.
| Author: | Greg Ondayko [ Thu Jun 11, 2020 2:13 pm ] |
I got it all finished except for reinstalling some small interior trim and a new Shifter ball. I don't have that much raw sheet metal or equipment to make a whole new tunnel. No english wheel power hammers etc. I did make a metal cover that screws to the floor around the shifter.. that way if I want to change the shifter I have topside access without removing the trans. Carpet fit okay, Its a bit wonky, but will suffice for now. Seats and belts are back in. Greg |
| Author: | Badvert65 [ Fri Jun 12, 2020 5:31 am ] |
Wow, that turned out very nice. Could be mistaken for factory stock. Stock engine?-well at least you can drive your car around and enjoy it. My hat's off to you. Lookin good. |
| Author: | Greg Ondayko [ Fri Jun 12, 2020 5:51 am ] |
Thanks Matt. Yep I drive all the cars in my collection.. Just like humans sittin' too much is not good. Drive 'em, Don't Hide 'em. Greg |
| Author: | Dan-o [ Fri Jun 12, 2020 8:54 am ] |
Quote: I got it all finished except for reinstalling some small interior trim and a new Shifter ball.
I hear ya. We don't have anything heavy enough at the shop either, but the local steel houses can usually get a piece pretty close as long as you have a radius for each end. One other issue I've seen with building them as you did...will you be able to get the trans out?I don't have that much raw sheet metal or equipment to make a whole new tunnel. No english wheel power hammers etc. I did make a metal cover that screws to the floor around the shifter.. that way if I want to change the shifter I have topside access without removing the trans. Carpet fit okay, Its a bit wonky, but will suffice for now. Seats and belts are back in. Greg We had a Belvedere that came in a while back with a TKO 600 swap, and the trans wouldn't come out without dropping the center link to get enough down angle to pull the trans out. He found out the hard way after messing with it in his driveway for 2 days. |
| Author: | Greg Ondayko [ Fri Jun 12, 2020 9:02 am ] |
Trans will come out. That is all built above the cutouts I created. The rear cutout has enough clearance for removal. Greg |
| Author: | Dan-o [ Fri Jun 12, 2020 12:33 pm ] |
Quote: Trans will come out. That is all built above the cutouts I created. The rear cutout has enough clearance for removal.
Very cool.Greg Thanks again for doing all the leg work on this swap and posting the guide. Its awesome to know that this is an achievable option for us. |
| Author: | Greg Ondayko [ Fri Jun 12, 2020 12:48 pm ] |
Yep, Thanks, no Problem Dan-o! I think I have been wanting to do the swap for about 15 years now, and I like to document stuff. Maybe I should go back to school and work for some automotive media company?!?! Will be gathering Interest on another Group BellHousing Buy so watch the Transmission and / or parts for sale forums for that too. Greg |
| Page 15 of 40 | All times are UTC-07:00 |
