| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 17 of 128 |
| Author: | Rick Covalt [ Sat Oct 22, 2011 8:01 am ] |
| Post subject: | Battery tray |
I was a little concerned about my battery tray fitting with the full sized alt. but it worked out fine. ![]()
| Author: | Will [ Sat Oct 22, 2011 8:42 am ] |
Isn't that what trunks are for? Will |
| Author: | Rick Covalt [ Sat Oct 22, 2011 10:46 am ] |
| Post subject: | Yes |
Yes, Will and it may end up there, but I am having a hard time deciding where to put the shut off! Rick |
| Author: | olafla [ Sat Oct 22, 2011 6:17 pm ] |
Rick, here you may find the clip you're missing, they claim to have The World's Largest Selection of Body Hardware and Specialty Fasteners auveco.com Olaf. |
| Author: | Rick Covalt [ Fri Oct 28, 2011 2:33 pm ] |
Thanks for the link Olafla. I see one that looks close but it looks like you have to buy 50. I have to do a little checking to see if there are any suppliers around here. With all the smack talk going on from Rob and Wayne and Dennis and Lou, I started to get a little skeered. But the big thing I got done was painting my garage 30 X 40'. Between 3 weeks of rain and now snow I'm glad its painted. Next time it needs paint it is getting vinyl siding! Got to get to the garage, I can hear Rob catching up! Rick |
| Author: | Rob Simmons [ Mon Oct 31, 2011 7:08 am ] |
Quote: With all the smack talk going on from Rob and Wayne and Dennis and Lou, I started to get a little skeered.
Bwahahahahaha!!! Got to get to the garage, I can hear Rob catching up! Rick |
| Author: | Charrlie_S [ Mon Oct 31, 2011 8:53 am ] |
Hey Rick, With all the time those guys are spending on here, running their fingers, they can't have any time left to work on their cars. |
| Author: | Rob Simmons [ Mon Oct 31, 2011 10:31 am ] |
Quote: Hey Rick, With all the time those guys are spending on here, running their fingers, they can't have any time left to work on their cars.
True Dat! I did sneak out at lunch today with the intent of picking up my '72 Dart from the glass shop... More in my "Don't hate me, but ... V8" thread... |
| Author: | Rick Covalt [ Mon Nov 28, 2011 9:37 am ] |
| Post subject: | Pinion Angle AGAIN!! |
Please double check my numbers. Car is setting on its wheels. I added weight to the trunk to simulate a full tank of gas. I have the rear end centered in the car(it was off 3/8") and am ready to tack on the spring perches. I only want to do it once! Reading on driveline 5 degrees down Reading on pinion 1 degree down If my math is correct 5+1 = 6 degrees / this is right in the middle of the 5-7 degrees that the M.P. book says is preferred. I'm ready to nail it down. Talk to me please! Out to the garage to start on some wiring/ignition stuff. |
| Author: | Romeo Furio [ Tue Nov 29, 2011 5:45 am ] |
I may be completely wrong but I thought that the pinion angle should be set at 7 degrees down for when the pinion crawls up the ring gear during starting line starts and all that torque down the track ?? Just asking a question not stating a fact. |
| Author: | Romeo Furio [ Tue Nov 29, 2011 5:50 am ] |
OPPS, almost forgot the driveline at a lesser 2 degrees down? Again just thinking out loud. |
| Author: | Romeo Furio [ Tue Nov 29, 2011 5:53 am ] |
One more time,, are your readings taken at the trans yoke and the pinion yoke ? |
| Author: | Rick Covalt [ Tue Nov 29, 2011 7:33 am ] |
| Post subject: | readings |
Readings taken off the driveline and off the pinion yoke, as it said in the MP chassis manual. I will check as Dennis mentioned in the other thread and get back to you Rick |
| Author: | slantzilla [ Tue Nov 29, 2011 7:56 am ] |
On a street car you want to end up with 3-4 down. The 7-8 referred to in the MP manual was for stick drag cars only. |
| Author: | Rick Covalt [ Tue Nov 29, 2011 12:29 pm ] |
| Post subject: | Final angles |
Quote: Ok Big D. Guidance appreciated! Laughing I pulled the driveline and here are my readings.
Off of transmission dust boot 4 degrees down Off of rear yoke 2 degrees down Sooo! if I understand (which I probably don't) In an ideal world I would want the rear at the opposite angle 4 degrees up, so the two offset each other. Then to allow for wind-up I need 3-4 degees down from the tranny reading. That would mean my rear yoke needs to be at 0 degrees to have 4 degrees difference? Right now I am at 6 degrees, and am not changing until I here from you! Laughing One other thing is that my car is a stock leaf spring car & automatic. It will be a 4 speed before it is all over. That article does not mention a stock leaf spring reading. Maybe my 6 degrees is OK?? Thanks a million, Rick [/quote]If it were me, I'd put the rear at 0 and call it a day.[/quote] Above is from the other pinion angle thread where Slantzilla help straighten me out! Rick |
| Page 17 of 128 | All times are UTC-07:00 |
