| HEI electronic ignition discussion https://slantsix.org/forum/viewtopic.php?t=28732 |
Page 18 of 35 |
| Author: | frcc [ Sat Jun 11, 2011 8:54 pm ] |
| Post subject: | 1983 D-150 EFCS Removal/HEI Install |
Problem : This Truck was running badly, many previous owners hacked, removed, replaced components and wiring such that the computer was not getting all the inputs it needed to function. Therefore the lean burn system "defaults" to get you home timing. The result high fuel consumption and poor performance. So bad in fact that the truck or the system had to go. It was a lean burn w/o 02 feedback. There are many ways to do the conversion this is just one ---- Some may consider this overdone....I agree,,, had time on my hands, and, I only like doing things once! I have visited this site many times and "taken" away a lot of information. This was an opportunity for me to "give back"to the forum. Many of you pros out there know this is a simple conversion. But, for some, it can be challenging. For me it was an opportunity to fabricate a solution and share it with others. Enjoy. ![]() ![]() Step 1 I Read info from here (hei section, and FORUM) regarding reasons to convert, technical advantages, parts needed, and How To. Step 2 Ordered "Shop Service Manual" from: politpaul@yahoo.com reasonable and professional, "no CD" "paper back original" ![]() Note: READ YOUR MANUAL! some electrical diagrams are posted in the previous post on this subject which relates to this modification! I will also modify a simple wiring diagram when finished posting Step 3 Consulted local Emissions people, and emissions map on truck to determine if truck would meet regulations with removal of "EFCS" Important, a little effort here will save you a lot of grief later, saving you money and repeat trips to junk yard looking for those parts you discarded!!! CONSULT YOUR OWN PARTICULAR STATE/COUNTY Step 4 Ordered Parts NAPA coil napa echlin # IC24 relay napa echlin # AR274 hei module napa echlin # TP45 coil wire napa belden # 701050 coil connector napa echlin # ICC1 heat sink ac delco # 00212G4 LC01 ACD# 10474610 leds radio shack # see pic,,many to choose from Some Photo's of the Individual Parts ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Ordered Carburetor from: Carburetor Specialist 5715 N Commerce Ct. Suite 200 Alpharetta,GA 30004-4178 (678)393-1501 My salesman was Greg Their Part # NC- 108-2404 Carter BBD/DC Note: These people are expensive but very competent. They will get you the right carburetor if you answer their questions. Replaced carburetor on truck with NEW mechanical, non-computer type BBD No pic of old carburetor as it was sent to shop in exchange for the new one. Installed the Carburetor and used old mechanical electric heated choke to test. Will probably replace with a mechanical cable type when conversion is finished. Step 5 Installed Carburetor - Test to make sure engine runs correctly. ![]() ![]() ![]() Ordered Distributor from: Old Car Parts NW, Inc 1120 SW 16th Street #7 Renton,WA 98057-2639 (206)300-1083 Email ocpnwi@gmail.com Replaced distributor on truck which was lean burn dual pickup, non vacuum advance, with Mechanical Electronic Vacuum Advance part # 3874714 as suggested on these posts Your manual may also have a P/N. See other parts of forum for Distributor variations and modifications. ![]() ![]() Step 6 Fabricated Unit Found window or door aluminumchannel at junk yard. Found heat sink at computer store scrap bin, came out of desktop computer (would be lower profile if you can find one from a server) Yep, went overboard with heat sink, "YOU" do not need that much. (personal philosophy, I OVERBUILD !) (a little about ht transfer later) Fabricated the above parts into the channel Used all stainless steel machine fasteners fastener sizes machine --6/32 8/32 10/32 10/24 (screws, flat & lock washers & nuts) Used shrink wrap when splicing Used insulated connectors and crimped wiring to them #12 #14 #16 Used quality automotive wiring ---#12 #14 #16 copper Used rubber hole grommets Used nylon wire holders fused main power supply to unit , (20A) #12 copper wire All grounding wires "non-insulated stainless connectors crimped" Use hi quality automotive electrical tape and tie raps Note: This is important, PUT 20A fuse assembly as close to the battery as possible. If there's an electrical fault in the system or between the battery and the system the fuse will protect the module and wiring to the module. Note: When placing hei unit make sure you place on flat,flush surface and use the dielectric grease. My hei (napa) had a couple of plastic placement dowels that i filed off, which then allowed it to lay flat and flush. Because of an irregularity in the door/window channel i selected, i used the GM AC DELCO heat sink so the hei unit would sit flush to the channel. This is important. *** Used the following WD's as a guide **************** Note: THESE ARE NOT MY DIAGRAMS, THEY CAN BE FOUND IN THIS SECTION AND ON THE NET. You will find full w/d in your manual and a good w/d for this conversion in the previous post in this section. Your best course of action is to GET familiar with Your car/truck by reading YOUR Owners Manual. ---------- Thanks to those who uploaded them ------- --- Will upload a simple W/D showing led's and pwr relay when finishing post ---- ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Don't like testing (lazy) so added led lights to tell me when i have RED........fused main batt voltage to unit AMBER....ingition switch on GREEN....output relay power to coil and hei unit "NOT REQUIRED FOR UNIT FUNCTIONALITY" Note: [led's are internally resisted, so you don't have to worry about installing 12v resistors for the led's] power consumption of leds will not effect full batt voltage to relay/coil/hei unit as the draw is extremely small. Will add wiring instructions for them as this post matures. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Fabricated tabs to hei module to fit on firewall http://i1138.photobucket.com/albums/n53 ... 024A-1.jpg Step 7 Install/ test New Distributor and Ignition Module Make sure you spend the time to "find" TDC "top dead center" prior to removing the old and installing your new distributor. (Many posts here and in your manual will guide you) Removed old coil, marked +/- wires with pen & masking tape Removed old Distributor and Installed new distributor, Notes:found timing slot on NEW distributor hold down mechanism slightly smaller than the hold down bolt. Hold down mechanism are different from my stock 83 D-150 and the older version distributor pictured as parts bought (probably mid 70's). Therefore, used a small round file to edge out the slot so that the hold down bolt would fit enabling the distributor to move freely from full retard to full advance positions. (Didn't take much too accomplish this) Don't panic if yours is a little tight also, just use the old round file. Look at the connector coming from your new distributor. If its a Dodge/Chrysler it may have (this connector see pic on my new dist) Don't know the name but it is a male/female prong socket type. Many 70's and 80's Dodge truck and vans (turn signal, parking, and stop lites) have this connection. I simply cut one from some of the junk i have and splice to wires that came with your new dist. WALLA-A Quick disconnect. You will find this handy in the future when removing the dist or the hei module you just fabricated. http://i1138.photobucket.com/albums/n53 ... 4-012A.jpg Another quick removal trick, when selecting the fender well site you r limited by the length of the coil leed to the dist. I fabricated module mounts so that the hei module could be removed quickly for repair without fumbling with the underneath firewall bolts. http://i1138.photobucket.com/albums/n53 ... 023A-1.jpg ![]() http://i1138.photobucket.com/albums/n53 ... 4-021A.jpg I used stainless fittings because its important to achieve and maintain good grounding. It won't rust. Keeping the unit away from fender well allows moisture and small debris to roll under unit. Complete module install on firewall. Test Module w/LED Installed: Make sure module ground wire is connected to GROUND on module bolt fender well (fabricate a jumper of #12 copper wire with a couple of alligator clips). Connect one end of alligator clip to the 20A fused wire from pos (+) side of battery. Briefly connect other end to main 12V side of module. This would be the main Input to the secondary or hi side of the power relay. You should see the module "RED LED illuminate" and no others. You should not hear a relay actuation sound. (RED LED is wired from secondary side relay input to ground via an internal resistor) Indicating battery availability. Disconnect jumper from battery Find (+) coil wire previously marked with masking tape during coil removal. Connect this wire to the low side of the power relay. Turn ignition switch to "ON" "NOT START" position. This will allow ignition voltage to flow through the primary side or low side of the relay to ground, thus actuating the secondary side relay switch. However since battery power is not connected via the jumper no RED OR GREEN LED will illuminate, only the "AMBER LED" illuminates. You will hear the power relay switch activate. Turn ignition switch OFF Reconnect the alligator jumper from the 20A fused battery power to the HI side or Secondary side of the power relay You should see the RED LED illuminated constantly Turn the ignition switch to ON You should see the RED LED, AMBER LED and the GREEN LED illuminated and the sound of the relay actuation. ALL LED's should remain on! Start Motor. Test Module w/out installation of LED's Testing module without LED's simply connect as described with LEDS. Start motor. If motor runs you can plan your wiring harness permanent installation. Note: Assuming you fabricated and wired the module correctly, installed the carb, and distributor correctly the engine should run. Only problem i had was I had to reverse the wires coming from the Distributor to the hei module, after that I thought I had a turbo charged slant/6. Good reason not to permanently wire anything except module until engine runs. Final Clean up of wiring harness w/o removal of old EFCS wiring. Simply finish hard wiring what you got and clean up the existing wiring harness. Final Cleanup of wiring harness with removal of old EFCS wiring. Following description is what I did. There are many many possibilities here. Understand your own vehicles options as they relate to the electrical,emission,fuel,vacuum etc systems. Decide what it is you want to be left with at the end of the conversion. Once I completed this I opened up the wiring harness by cutting the harness tape and spreading the wiring out. For your ignition module you only needed the ignition wire from the coil and a fused power supply from the battery as well as good grounding and the necessary connections to the distributor. Once you "OPEN" up the wiring harness the layout of the lean burn system appears straight forward despite the amount of wiring I planned on removing. My plan was to remove "ALL" the lean burn system. In addition I wanted to remove the electric choke, electric temperature and oil pressure senders and gauges. This would leave a pretty sparse and simple electrical system under the hood. * working on w/d and resizing pics, processing more pics, adding links to load quicker jeff 08/12/11 ------ continued -- |
| Author: | KenUSA [ Sun Jun 12, 2011 7:53 pm ] |
frcc- Great photo log. I did the conversion last year with substandard parts. Its amazing how a faulty charging system can screw up an ignition system and vice versa. All better now with all premium parts. Bite the bullet and buy the good stuff. PS GM alternator pigtails work very well for module connections- around 3.00 |
| Author: | Ross [ Sun Jun 12, 2011 8:03 pm ] |
That looks very professional, i like it. Makes mine look like a rookie did it, oh wait.... a rookie did do it Cody |
| Author: | Joshie225 [ Sun Jun 12, 2011 9:47 pm ] |
Holy heatsink Batman! You know that little heat sink under the module is all that you need right? GM used one just like your little one on LT1s and bolted it and the coil to a bracket on the front of driver's side cylinder head. Here's my LT1 coil, bracket and heat sink with a 4-pin module. All of this is original GM stuff from a wrecking yard.
| Author: | Reed [ Sun Jun 12, 2011 10:49 pm ] |
Wow, very nice writeup! I actually was the guinea pig for Goldduster318's (Pat) testing of the HEI conversion. I did the swap on an old 74 Valiant I used to have. Worked great without a relay and without a heatsink. Two suggestions- add the part numbers for the parts you ordered and provide a wiring diagram for the addition of the LEDs. Nice job. |
| Author: | olafla [ Mon Jun 13, 2011 2:28 pm ] |
Jeff, that is very nice work, and great documentation. Olaf. BTW, you should rescale your pics to 400x300, as it is now the page opens a bit slow. |
| Author: | krytellan [ Sun Jun 19, 2011 8:27 am ] |
I was hoping someone could give me a good idea of the best option for wiring #86 (trigger feed) from the relay. That is, a good source to connect it to. |
| Author: | Wagonmaster79 [ Thu Jun 23, 2011 4:25 pm ] |
Glad this topic is still going.I have just a couple of questions.I got the coil/heat sink combo shown in the picture in the other thread that DOES NOT have the 4 pin set up..it was off of a '00 S-10.I don't see anywhere to get voltage to the coil as I only have 2 wires that come off the connector that come from the coil.My ballast resistor has 3 wires going to it also,2 onto the prong on the pass side of the resistor and a single on the driver side,do all 3 get spliced together?My big problem really is finding how to get power to the coil.I will try to post 2 pics of what I have once I get them uploaded. Thank You Ronnie <a href="http://s1221.photobucket.com/albums/dd476/wagonmaster79/?action=view¤t=001.jpg" target="_blank"><img src="http://i1221.photobucket.com/albums/dd476/wagonmaster79/001.jpg" border="0" alt="Photobucket"></a> |
| Author: | olafla [ Fri Jun 24, 2011 3:40 pm ] |
Hi Wagonmaster79, and welcome to the forum. Please tell what model and year your car/truck is. (hmm, could be some '79 wagon, but hey, I'm just guessing wildly here...) Olaf. |
| Author: | Wagonmaster79 [ Sun Jun 26, 2011 8:24 pm ] |
I'm sorry,yes it is a '79 Aspen Wagon lol |
| Author: | olafla [ Sun Jun 26, 2011 10:25 pm ] |
Do you have a lean-burn setup with a computer in the air filter box, or the standard eletronic ignition? Olaf. |
| Author: | olafla [ Sun Jun 26, 2011 10:47 pm ] |
Krytellan, the wire feeding the ballast resistor would be a natural source to trigger the relay. Olaf. |
| Author: | Stoopid john [ Sat Jul 02, 2011 7:37 pm ] |
I just did the HEI swap on my 67 a100 van, WOW, what a difference. Thanks All john |
| Author: | krytellan [ Sun Jul 03, 2011 6:18 am ] |
Quote: Krytellan, the wire feeding the ballast resistor would be a natural source to trigger the relay.
Thanks Olaf. That's what I ended up using. I have to admit I was more than a little surprised that after only about 90 minutes, I was all done with the project.... AND it was all done right the first time. Olaf. Unlike others, I see minimal difference so far, other than somewhere b/w 1 and 2 MPG (which I know can be significant). I'll withhold judgment until I run all new 2-1/4" exhaust this week. The two together will probably produce great results. |
| Author: | the_shadow [ Sun Jul 10, 2011 11:42 am ] |
I just hooked up my HEI and the car was running, however I wanted to bounce a wiring question off you guys before I go any further. I got a custom wiring harness made (ballast resistor deleted) from Evan's Wiring. He left a purple with white stripe wire and a slightly thicker gauge brown wire in the distributor area for me to hook up to the HEI module. I tried to call Evan's Wiring but I think they are out of town for the weekend. Anyway the brown is +12v while cranking only. The purple with white stripe is +12v while running in the 'on' position only. THE QUESTION: am I correct in assuming that I am supposed to hook those wires together and to the +coil and +module? That's how I have it hooked now and it ran just fine. I just didn't see seperate +12v (one while cranking, one while ignition on running) in any wiring diagrams. I am not the best electrical guy so I wanted to check first before buttoning this up today. Thanks!! |
| Page 18 of 35 | All times are UTC-07:00 |
