It is currently Tue Jan 07, 2025 2:32 pm
Post new topic  Reply to topic  [ 526 posts ]  Go to page Previous 116 17 18 19 2036 Next
 Post subject: 8/23/20
PostPosted: Sun Aug 23, 2020 7:37 pm
Today was a good Day.
Got to take a nice 2 hour Drive over the mountains to the AutoX site.
Got 6 runs in.. Nothing broke or blew up.
Went off course first 2 laps, Then got it figured out. As the Car got hotter and I pushed harder it slowed down due to the Fuel Starvation on RH. Turns. I believe the Carter BBS 1 Bbl only has one Jet / Metering Rod and it's on the Right side of the Carb... I will look into that this week.
The Carter Designers should have really took this whole AutoX thing into account when they were designing their BBS 1 barrel carb in the 1950's :D
I think I might try putting a baffle in the float bowl and also raising the float a but more too.
The CPR Region of the SCCA did a fantastic job organizing the event and I have 160 or so Photos of the car too!..
So for the car's First official AutoX Event I am happy. It wasn't the slowest thing there and it seemed to handle well for what it is.
Results:
https://scca-cpr.com/site/wp-content/up ... 09_raw.htm
Some shots..
On the Drive up..
In the paddock:
The Club took great photos!
Here are some:
'Till Next time!
PostPosted: Mon Aug 24, 2020 4:39 am
Very nice, Greg. Now you have a baseline.
PostPosted: Mon Aug 24, 2020 5:09 am
Nice going Greg! Hopefully you can figure out something with the carb
Brian i
Flyin' Brian
"Sixy Beast"
PostPosted: Mon Aug 24, 2020 6:15 am
Hi Brian,
Good to see you around!
I might figure it out... or maybe not.. its only going to be around as a 1 bbl a few more months anyway.
I jus' figured I will I will go FULL MIMKEN with it and see what happens. :D
PostPosted: Mon Aug 24, 2020 7:32 am
Oh, don't ever go full Mimken...
Speaking of carbs, I am such a nit picker, that I think I cannot deal with carbs much anymore. I have spent time in the 62 Valiant trying to get the Hly 500 to behave under all conditions, and so I am constantly fiddling with it. Can't wait to get the new IR intake/TBs on there and megasquirt it. Can't beat carbs for simplicity, though.
Had a nice call from Mr. Mimken yesterday - golden.
PostPosted: Mon Aug 24, 2020 8:03 am
Yes I see Ir's and some other stuff in the future.
PostPosted: Tue Aug 25, 2020 10:55 am
Greg, I only recommend going Full Mimken for short bursts of time! Oh, and definitely not in front of the boss (work or home)! It does come in handy though :mrgreen:
Brian
*Note to self- if I start letting all of my secrets out, I'll probably get banned from reputable places.*
Also, I am currently doing side gigs posing as a restaurant host/hostess. Let me know if you would like to hire me!
Flyin' Brian
"Sixy Beast"
 Post subject: 9/23/20
PostPosted: Wed Sep 23, 2020 10:46 am
Getting some work done on the mighty 1 bbl - It had some fuel starvation issues pretty consistently in the last 2 outings of autoX on Hard R Turns - Fuel Sloshing away from the one Jet(located on the right side in the fuel bowl) in this carb.
I built a small baffle that hopefully will help.
I tried to drive it to work today, but It wouldn't' start. Maybe I set the float level too High... Those floats must be touchy in regard to level changes. I will pull the plugs and see if I flooded it and will also make sure there is spark.. will double check carb float levels and reset to stock if needed.
Some pics of the mighty autocrossing 1 bbl...
 Post subject: 10/15/20
PostPosted: Thu Oct 15, 2020 6:54 am
Well the Baffle Idea in the BBS had me baffled.... ha.. no It did not work.
Took the car to the Salem, Va AutoX and Still had Fuel starvation / Bucking issues with the car in Hard R Hand Turns. It was a blast however seeing some Stout Corvairs and Mustang II tearin' up the cone course.
I also was able to do some mountain Driving with friends on the Back of the Dragon from Marion to Tazewell Va.... whatta Fun Road!
http://www.slantsix.org/forum/viewtopic ... 42&t=65306
I got Back home and last night the girls wanted to go to dinner and the fall weather was just right.. so a ~270 Mile Drive to Summit Racing in Tallmadge seemed appropriate. All interstates this time.
- Was able to procure some goodies for various projects including an aem 30-0300 and a Set of Enkei RPF01's for Grüne Hölle. We ate dinner near Kent State Univ, before heading home.
Also Found a decent fix for my Smashed Driver's Side Door armrest. I did a pile driver move on it with my elbow at the autox Course in Virginia. It was toast.
after I smashed it, I removed it from the door.
And Came up with a lighter more pliable alternative.. Dog Leash.
I can still pull the door shut when needed.
Future (Winter) Plans include:
-Building a Proper oil pan - I mean you can't go to moroso or canton or stefs for Slant 6 pans...
-Mounting the Falken Azenis's on the RPF01's
-Fitting the Fiberglass Hood
-Installing a proper engine / Intake / Exhaust with O2 Sensor
-Maybe fit up some better front Seats
Cheers, Greg
PostPosted: Thu Oct 15, 2020 7:16 am
Sounds great, Greg. Congrats on the progress and the fun driving.
 Post subject: 10/19/20
PostPosted: Mon Oct 19, 2020 1:16 pm
Something arrived today..
PostPosted: Mon Oct 19, 2020 1:27 pm
Woo, those have a lot of positive offset; about 17mm more than you need. Were you planning on running a spacer? 3797806535SP looks like a better fit.
PostPosted: Mon Oct 19, 2020 2:31 pm
Running a 69 B body rear end. Hope to :shock: be okay.
PostPosted: Mon Oct 19, 2020 6:00 pm
When I put an 8 3/4 under the '66 Barracuda it was the slightly narrower '67 B-body axle and it fit well with 17x8" +30mm wheels with 235/40R17 tires. There was just a little more inboard clearance than outboard. Google Drive doesn't make image sharing that easy, but if you follow the links you'll see what I mean.
https://drive.google.com/file/d/17w3iOU ... sp=sharing
https://drive.google.com/file/d/1kQpHlU ... sp=sharing
https://drive.google.com/file/d/168FuAL ... sp=sharing
PostPosted: Mon Oct 19, 2020 6:26 pm
I just get a spinning circle......
