| Slant six with overdrive 4 speed auto https://slantsix.org/forum/viewtopic.php?t=13144 |
Page 3 of 3 |
| Author: | vynn3 [ Thu Oct 27, 2005 6:05 am ] |
I've heard some concerns about the pinion angle of the shorter driveshaft because of the length of the GV unit used in an A-Body. Anyone experienced any issues or heard of any failures? VM |
| Author: | 440_Magnum [ Fri Nov 04, 2005 8:19 am ] |
Quote: I've heard some concerns about the pinion angle of the shorter driveshaft because of the length of the GV unit used in an A-Body. Anyone experienced any issues or heard of any failures?
I imagine that is a possibility, but if you keep the angles equal and opposite, it shouldn't be a problem. 4x4s and heavy trucks run with much bigger angles, even though the driveshafts are longer. The biggest mistake people make is "correcting" the angle at the rear end- IOW shimming the axle so that the pinion points up toward the transmission. That keeps the rear U-joint straight, but does nothing for the front one. When the U-joint angles don't match, you get speed variations at the output of the second U-joint and thats what causes stress. If the angles are equal, then the driveshaft speed varies twice per revolution, but the rear U-joint exactly cancels the speed variations of the front joint, and everything's OK.VM I haven't specifically heard/read about any problems cropping up with GVO unts. |
| Page 3 of 3 | All times are UTC-07:00 |
