Slant Six Forum https://slantsix.org/forum/ |
car audio https://slantsix.org/forum/viewtopic.php?t=14362 |
Page 3 of 4 |
Author: | carrigan #3 [ Sat Sep 24, 2005 7:59 am ] |
Post subject: | |
awesome...let me know what the dimesions are when u get the car....otherwise if u still have the instructions u used those would be awesome (maybe pm me and i'll give u my email?) thanks |
Author: | Rust collector [ Sat Sep 24, 2005 1:45 pm ] |
Post subject: | |
The instructions are for the speakers I have, install some other kind of speaker, and the box will need to be different. ANY good speaker comes with instructions about box size, shape, and different types of boxes, that fit YOUR speaker. Or you can use the different "measurements" that is listed for your speaker, and give to a GOOD installer. He will put the numbers in a computer, and give you the box drawings... If you give him the size/shape of the area the box will be in, he may be able to adjust the drawing to fit real nice... Anyway, this box is going OUT! It is too damn heavy, and takes a lot of room I need for camping gear, and/or beer... |
Author: | Avenger2040 [ Sat Sep 24, 2005 2:40 pm ] |
Post subject: | |
Quote: It is too damn heavy, and takes a lot of room I need for camping gear, and/or beer... You say??Make a picture with this, two Subwoofers of 12" below my 6x9 speakers, 2 amps (44cm long and 35cm wide) side by side, and in the side walls of the trunk, the other 2 Subwoofers of 12", that really takes room!! |
Author: | Rust collector [ Sat Sep 24, 2005 3:49 pm ] |
Post subject: | |
But it makes for nice wheelies ![]() ![]() ![]() ![]() |
Author: | NewLancerMan [ Sat Sep 24, 2005 7:09 pm ] |
Post subject: | |
Quote: rear speakers are under acustic carpet so they aren´t visible, middle speakers are also covered by acustic carpet in the rear side panels, front speakers are almost visible in the kick panels, stock speaker is not visible, tweeters are visible also the CD receiver
Sounds good to me. What'd you do for your head unit?
Woofers and amps are in the trunk, woofers in acustic boxes. I think they are well hidden., what do you think |
Author: | Avenger2040 [ Sat Sep 24, 2005 7:54 pm ] |
Post subject: | |
Ok, let me quote myself NewLancerMan Quote: My sound configuration is this one:
Alpine CD receiver 2 6x9 Audiobahn Speakers 4 5 1/2 Audiobahn Speakers Remplaced stock dash speaker with a new Audiobahn 8 Audiobahn Tweeters 4 12" Subwoofers 4 2,000 watts amplificators 2 Crossovers for the 6x9 speakers 4 Crossovers for the 5 1/2 speakers 1 Crossovers for the dash speaker 1 10 channels equalizer Thats all |
Author: | NewLancerMan [ Sat Sep 24, 2005 8:00 pm ] |
Post subject: | |
guh duh, I saw the list, I meant where did you put it? Following your stealth plan, I was curious how you hid it. My stock unit is fully functional and nice, and my glove box is fabric and thus not really optimal for mounting a hidden head, so that's why I asked. Not trying to call you out or something LOL |
Author: | emsvitil [ Sat Sep 24, 2005 8:06 pm ] |
Post subject: | |
And what's the matter with an original vintage 64 AM radio with the original vintage speaker?????????????????? ![]() |
Author: | exoJjL [ Sat Sep 24, 2005 8:25 pm ] |
Post subject: | |
Quote: And what's the matter with an original vintage 64 AM radio
my 1973 speaker practicly crumbled to dust when i took it out. hehe
Author: | Avenger2040 [ Sat Sep 24, 2005 8:33 pm ] |
Post subject: | |
I just simply throw away original radio and put there my Alpine receiver, since is a very old model, no one wants to stealth it, but I will change it soon for a better receiver with removable plate and make a door or something to keep hidden the receiver. |
Author: | emsvitil [ Sat Sep 24, 2005 8:37 pm ] |
Post subject: | |
Quote: [my 1973 speaker practicly crumbled to dust when i took it out. hehe
It sounds like I should replace my vintage speaker; but with a quick glance at it from under the dash, I haven't figured out how to get it out.. ![]() |
Author: | Avenger2040 [ Sat Sep 24, 2005 8:42 pm ] |
Post subject: | |
Quote: It sounds like I should replace my vintage speaker; but with a quick glance at it from under the dash, I haven't figured out how to get it out..
For that reason I keep using my stock speaker, and for the way it sounds, it is in very good shape.![]() Anyway, someone knows a easy way to remove stock dash speaker? |
Author: | carrigan #3 [ Sat Sep 24, 2005 9:09 pm ] |
Post subject: | |
i'd say the easiest way to remove it is to leave it where its at ![]() but that's just me being lazy.... |
Author: | NewLancerMan [ Tue Sep 27, 2005 11:53 am ] |
Post subject: | |
Mine sounds ok once it gets warmed up with the original vintage speaker?????????????????? ![]() ![]() Besides, the grill is pretty darn fragile. You have to pry at it, which gives you a good chance of breakage. Avenger, I had a writeup someone did on putting two 4" speakers side by side up there to get stereo, I'll see if I can find it. He had some info on removing the grill IIRC. MJ |
Author: | emsvitil [ Tue Sep 27, 2005 3:59 pm ] |
Post subject: | |
![]() MJ Only get AM talkradio down here.......... ![]() I'd be happy with a top 40 station........... ![]() |
Page 3 of 4 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
