| Turbo or Blown??? https://slantsix.org/forum/viewtopic.php?t=16697 |
Page 3 of 3 |
| Author: | mopardemon71 [ Thu Mar 30, 2006 11:52 am ] |
MichB, look you can use BOLD LETTERS ALL YOU WANT. I was just putting in some info. detroit 60 engines are a 4 stroke v 92's were two stroke.the turbos had tiny compressers thats the huffer's job and untill mid90's there was no serious emission testing for off highway motors The point I am saying is this, the speed at which exhaust gas goes thruogh the turbo housing creates the boost. STS makes a turbo system that bolts to the end of the exhaust pipe for the new dodge hemi trucks by the rear axle, not as muh heat there but it make as much power as a medium size roots. look I'm not here to piss any one off but if you cant listen to someone else's ideas and not get mad dont post. isaid in my frist post that I wasnt being rude. |
| Author: | DionR [ Thu Mar 30, 2006 4:50 pm ] |
You might try and find a copy of the boost comparison article that Hot Rod did a couple of years ago. They put a roots, centrifugal and a turbo all on the same motor (at different times; duh For my money, the turbo is the only way to go. With a roots or centrifugal, you have parasitic drag at ALL times, while the parasitic loss of a turbo under cruse conditions is very small. Horsepower when you want it and efficiency when needed. Best of both worlds. |
| Author: | Tom Drake [ Fri Mar 31, 2006 9:49 am ] |
Quote: "Run at 11 psi, the turbo kit pumped out 750 hp and 679 lb-ft of torque, bettering all three of the superchargers [Vortech, Kenne Bell and Eaton]....once the tach needle swung past 3,600 rpm, it was all turbo. How does an extra 178 hp and 154 lb-ft. or torque sound? While the turbos were down by as much as 100 lb-ft at 2,500 rpm, they quickly made up for lost time by eclipsing the Eaton and producing the most impressive post-4,000 rpm power curves of the bunch." - Richard Holdener - MM&FF, December 2004
Quote: August 2003 - Cover Feature Article - "Boost Shootout"
http://www.ststurbo.com/turbo_vs__supercharger
A Performance Comparison of Turbos vs Superchargers. "Given equivalent vehicles, the turbo would easily motor away from the centrifugal in an acceleration contest......The turbo offered massive midrange torque production, the only system to exceed 600 lb-ft. Need more convincing? At 4,000 rpm, the turbo was more than 100 lb-ft. stronger than either the Roots or centrifugal." - Battle of the Boost, Hotrod Magazine, August 2003 |
| Author: | mopardemon71 [ Fri Mar 31, 2006 9:55 am ] |
with the port set up on the /6 it is good to use a turbo, but the exhaust manifold would be custom.....pricey. Mr. Norm up in the mid-west put centrifugal's on those demons and I have a article where a guy has a paxton on a /6 duster. Looks like he use a/c brackets but the close-up pic's aren't that good. |
| Author: | vynn3 [ Fri Mar 31, 2006 10:52 am ] |
I still find this intriguing: http://gatorsuperchargers.net/photos/photos.htm But since I have no experience with either turbo nor supercharged engines, and lack fabrication skills and equipment, I'll guess I should leave it to those more capable. VM |
| Author: | DionR [ Fri Mar 31, 2006 12:33 pm ] |
Boy, I don't know. Seems a little too good to be true, no intercooler needed. I guess with no exhaust heating the housing, it might run cooler, but most of the heat comes from compressing the charge, not heat in the housing. Can't get around physics.Also, you still have the ratio problem. In order for that thing to spin 90,000 rpm (approx., in order to make max boost) when the motor is at 4500, you would need a 20:1 ratio. To make boost at just off idle, I bet it would need a 24:1 ratio. Ever spun the rear wheel on a RWD car (off the ground and in neutral)? Bet it wasn't real easy, and that,s at some mid 3:1 ratio. Try it at 20:1. Your on the wrong side of the lever arm. My opinion? Add a belt to a turbo, loose hp. Gotta give him credit for thinking outside the box, though. |
| Page 3 of 3 | All times are UTC-08:00 |
