Is anyone interested in buying some custom turbo headers?
https://slantsix.org/forum/viewtopic.php?t=21581
Page 3 of 3
Author:  CStryker [ Mon Feb 05, 2007 12:46 pm ]
By the way, how do you get a posting here to show up as a link that can simply be clicked on? I was under the impression that typing .com did that, but apprently not.
Sam, to do that you begin the address with the "url" tag and end it with the "/url" tag. you can either type those in square brackets "[]" or use the URL button above the message composition window. Just click the button which inserts the tag then type your link address then click the button again to insert the closing tag.
Just FYI, using "code" tags you can type the example directly to eliminate any possible confusion... I've seen enough people on this forum use goofy formatting to explain proper usage of tags so many times that I've begun wondering if people know that's what code tags are for. To answer the question, a link would be typed like this:
Code:
[url]www.slantsix.org[/url]
Author:  james jaggers [ Wed Feb 07, 2007 3:11 pm ]
Post subject:  just for you Ron!
I have started on your turbo header. I will be posting some pictures later tonight on my website.
Author:  dakight [ Wed Feb 07, 2007 6:05 pm ]
Code:
Well, ya learn something new every day! Even at my age. Thanks!
Author:  james jaggers [ Thu Oct 04, 2007 3:31 pm ]
Post subject:  header
I am going to try a different set up, moving the turbo forward towards the grill. I will be posting pics soon.
Page 3 of 3 All times are UTC-07:00
