California Emission Holley 1920 Vs Non?
https://slantsix.org/forum/viewtopic.php?t=24569
Page 3 of 3
Author:  SlantSixDan [ Wed Aug 22, 2007 12:08 pm ]
What exactly did you find? What-all are you including when you say "an electronic ignition"?
Author:  70Dart [ Wed Aug 22, 2007 12:35 pm ]
A cardone distributor with vacuum advance. A control module and connector. They are from auto zone.
Links:
http://www.autozone.com/R,APP38579/vehi ... Detail.htm
http://www.autozone.com/R,APP1478703/ve ... Detail.htm
http://www.autozone.com/R,APP36096/vehi ... Detail.htm
Im pretty sure there's more to it
Author:  SlantSixDan [ Wed Aug 22, 2007 1:22 pm ]
Yeah...you are begging for trouble and unreliability if you buy "remanufactured" trash from Cardone.
Here, buy one of these complete brand-new setups:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0162984970
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0120118447
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0098694892
Both vendors are reliable.
Author:  70Dart [ Wed Aug 22, 2007 1:29 pm ]
thanks, thats perfect.
Author:  ESP47 [ Wed Aug 22, 2007 10:43 pm ]
Does the hose from the distributor to the carb connect to a little cylinder thing along the way? I believe it's bolted to the top of the head or the valve cover. If so, bypass that and just use a connecter to connect the hose straight from the distributor to carb. That fixed some of the hesitation my car used to have. I don't remember what the name is called. Its not that OSAC deal. I think Dan knows the name of it.
Author:  70Dart [ Thu Aug 23, 2007 1:03 am ]
nope, its a direct connection. But my vacuum pod is shot.
Author:  SlantSixDan [ Thu Aug 23, 2007 9:00 am ]
That sounds like the '71 California NOx control system which prevented vacuum reaching the distributor until the car was in 3rd gear (with handshift transmission) or above something like 40 mph (with automatic). This system, like the OSAC that replaced it, works best when it's installed at the bottom of a landfill somewhere.
Author:  DusterNovice [ Tue Feb 04, 2014 3:12 pm ]
Sorry to resurrect this ancient thread, but I didn't see the need of creating a new topic for a small question that seems extremely relevant to this discussion.
I have a small circular device connecting the vacuum hose that goes from the distributor to the carburetor. It's about an inch in diameter, half is green and the other half white. It marries the two hoses right where the valve cover is but isn't bolted down. What does this do? I can't find any mention of it anywhere. Should I bypass it?
Author:  DusterIdiot [ Tue Feb 04, 2014 4:48 pm ]
Post subject:  Yep..
Should I bypass it?
It's a timing delay device I'd bet like the later ESC, yes you can bypass it and run the hose from the carb to the vacc. advance can on the distributor.
Page 3 of 3 All times are UTC-07:00
