Ram Air Design. Need your thoughts so far.
https://slantsix.org/forum/viewtopic.php?t=26992
Page 3 of 3
Author:  terrylittlejohn [ Sun Mar 02, 2008 7:26 am ]
Post subject:  ram air
i don`t understand why so many think ram air is not effective, all normally asperated cars will benefit from a forward facing inlet that creates pressure, on my 75 duster i had a snorkel scoop 6in high and i had 2inlbs pressure at 90mph at manifold when i sealed it to the carb, bren if you have header now your slower performace is most likely jetting, headers will effect your jetting , usually making it leaner, also you have to check pressure at the manifold and make sure it dozen effect your power valve. :?
Author:  1974duster kev [ Mon Mar 03, 2008 4:56 am ]
sweet, i'm inspired to finish my cold air i have a snorkel hoodscoop on my duster should be easy to do
Thanks, Kev
Author:  Aggressive Ted [ Mon Mar 03, 2008 9:59 am ]
Hooked up mine a month ago and it runs much smoother and has allot more power.
Page 3 of 3 All times are UTC-07:00
