| Distributor spring recommendations https://slantsix.org/forum/viewtopic.php?t=30579 |
Page 3 of 3 |
| Author: | Reed [ Mon Aug 25, 2008 12:59 pm ] |
| Post subject: | The saga continues.... |
This morning I went to the local pull-a-part and cleaned them out of slant six distributors. I got one off of a 76 Aspen wagon, a 73 Valiant sedan, and an early 60s Dodge? b-body sedan (the front clip was gone as were all the badges). I brought them all home, cleaned them up, and dissected them. Here are the results: Distributor 1 source: 1976 Aspen wagon- one-barrel, base timing 2 BTDC distributor tag number: 3874598 Vacuum advance: 8.5R, factory settings vacuum starts at 7, all in by 14 governor: 13R Springs: ![]() Distributor 2 source: 1973 Valiant sedan- a/c, p/b, one-barrel, base timing ??? Distributor tag number: 3755042 Vacuum advance: 8.5R, factory settings start at 7, all in by 14 governor: 15L Springs: ![]() The heavy spring is so long it almost touches the body of the distributor, but doesn't. Distributor 3 source: mystery early 60s mopar sedan, no options, base timing??? Distributor tag number: 2444254 Vacum advance: 6.5X, pod didn't hold a vacuum Governor: 11.5 springs: ![]() This is a very nice distributor. The springs actually fit over little towers that have a "T" on the end to hold the springs on. Also, the distributor has a cute little oiler on the side for the bearings! How cool is that! ![]() In addition to these distributors, I have the parts I mentioned above (9R governor, various springs, vacuum can that comes in above 10, and a VC-208 vacuum can). So here's my question: which one of these, or what combination of parts would work best in the motor in my brother's van? Right now I am going to try the stock 76 aspen distributor since the motor in the van is a 76 and since the van weighs about the same as the aspen wagon (roughly 3000 pounds). I will try it with the base timing at 2 and go from there. However, I am very open to suggestions about what parts to mix and match to get better gas mileage and performance. I also plan on mapping the mechanical advance curve for each of these distributors before i start swapping the guts around. I just need to figure out how to put EI guts into the early 60s points distributor... Thanks in advance for what I know will be valuable tips. |
| Author: | Reed [ Mon Aug 25, 2008 4:16 pm ] |
76 Aspen distributor mechanical advance curve: Factory base timing = 2BTDC 500 RPM = 2BTDC 750 RPM = 8 BTDC 1000 RPM = 15 BTDC 1400 RPM = 20 BTDC 1850 RPM = 20 BTDC starting to get twitchy, +/- 1 degree 2100 RPM = same as 1850 2400 RPM = same as 1850 My under-hood tach runs out at 2500 RPM on the 6 cylinder scale. Looks to me like this distributor relies on vacuum advance to get the final ten degrees or so of advance. P.S. A quick test drive tells me that this distributor feels pretty good in the van. Decent acceleration, smooth idle, no pinging. Next up is the Valiant distributor. 73 Valiant mechanical distributor curve test Factory base timing = TDC 600 RPM = TDC 750 RPM = TDC 800 RPM = 2BTDC 900 RPM = 8BTDC 1100 RPM = 11BTDC 1350 RPM = 20BTDC 1500 RPM = 22BTDC 1550RPM+ = 22BTDC So adjusting for the difference in base timing, it looks like the Aspen mechanical advance curve comes in earlier and advances less, and the Valiant curve comes in a smidge later and advances more. I think I am going to stick with the Valiant distributor right now in the van and see how it does. |
| Author: | Reed [ Mon Aug 25, 2008 7:31 pm ] |
| Post subject: | I'm calling it good! |
I decided to go with the stock distributor for the 73 Valiant but bump the base timing up 7 degrees. This should get my brother about in the ballpark. I'm not going to kill myself over this because he still might end up selling the van and all my work will have been for naught. Thanks for the help! |
| Author: | DusterIdiot [ Mon Aug 25, 2008 7:38 pm ] |
| Post subject: | Yep... |
Set '73 dizzy base timing to 8 BTDC and let it ride... The '76 would be better saved for that whaleback project you are dreaming up... -D.Idiot |
| Author: | Reed [ Mon Aug 25, 2008 8:25 pm ] |
Whaleback project? Now I got a bunch of extra distributors and no motor that can use them.... |
| Author: | Reed [ Tue Aug 26, 2008 9:03 pm ] |
WOW! I just took the van back to my brother so I got to do a long (40+ mile) highway trip. All I can say is WOW! Plenty of power AND I estimate the highway gas mileage at 20-21 MPG! That's right, 20 MPG from a slant in a VAN! THANK YOU to everyone who has contributed advice and parts! I couldn't have done it without you. This place and its members are the BEST! |
| Author: | DusterIdiot [ Wed Aug 27, 2008 5:47 am ] |
| Post subject: | Jeez... |
Quote: Whaleback project? 1964-1966 Barracuda.... -D.Idiot |
| Author: | Reed [ Wed Aug 27, 2008 8:11 am ] |
Heh, if only I had the space, time and money! |
| Page 3 of 3 | All times are UTC-07:00 |
