| Any door cars under 2000 lbs.? https://slantsix.org/forum/viewtopic.php?t=32454 |
Page 3 of 4 |
| Author: | NCDemon1971 [ Mon Dec 01, 2008 1:41 pm ] |
I dont know what Id be in for in the quarter mile but as far as 1/8 mile time goes the '66 barracuda in the next two to three years once I get it completed it should run 7.90's hopefully. Gutted as far as you can go with a home built tube chassis and an aluminum floor, and plexi windows. Hope to make it toward 2000# even. Time will tell. |
| Author: | sergio [ Fri Dec 26, 2008 9:13 am ] |
Hope everyone is having a great holiday season. I finally scaled several cars to determine actual potential for weight loss. First 69 dart as raced last season, no back seat light wheels other misc removed but no cutting,2727w/o driver. 64 dart sedan as raced at last redding race 2490 no front bumper one race seat ,heater core gas tank etc removed but no cutting.Now for the secret project its a 70 cuda 14point cage everything fiberglass,with sl6 cast iron manifonds,heavy factory discs amd 15inch big tires out back,stock front steel wheels . 1773 w/o driver,car needs another 450 lbs for a total of2223 ready to race.I know from past projects an easy 100 lbs can come off the front end,and another 50 fron excess material making it 2073.wheels and tires another 50,so it looks like 2000 w/o driver is possible. Also this car wont certify so a few pipes could be removed.This will be a slow process wont be ready till at least summer,i will update every few weeks, may need a jockey for a driver but i think it can go under 2000 with driver. |
| Author: | Fopar [ Fri Dec 26, 2008 10:31 am ] |
I weigh 138#, might be available if it doesn't come down to your car against my car |
| Author: | Charrlie_S [ Fri Dec 26, 2008 11:36 am ] |
Quote: Also this car wont certify so a few pipes could be removed.
Better check the rules. I don't know for sure, but I think any safety devices, that are installed, must meet the rule book, even if they are not required.
| Author: | wayne erickson [ Sat Dec 27, 2008 8:46 am ] |
Wow..the secret project is finally out....I need to come over with my bathroom scales...Sounds like a neat project....I need to see it first hand....What rear end are you planning on using? 8" Ford or big Mopar? Don't forget fuel @ 7# per gallon...I hear Glen might also be looking for a faster new ride this year..?? Take care, Wayne |
| Author: | Ron Parker [ Sat Dec 27, 2008 2:24 pm ] |
Know Glen checked on a fast Chalenger this past week a 11 second car. Thanks Ron Parker It Aint Over Until I Win |
| Author: | ceej [ Sat Dec 27, 2008 4:38 pm ] |
I've been hoping he could pull that purchase off! CJ |
| Author: | sergio [ Sat Dec 27, 2008 5:28 pm ] |
Yep,Glenn wants that Challenger, Wayne it has an83/4 with ladder bars and 4.88s,but i may put a ford8.8 with a mini spool,another 50/75 llbs off.This car will be legal to 10.00 only because some of the bars are not the correct wall thickness but it was formerly a 7.50 legal chassis. I told Glenn if he wants to dump his piece and buy a motor with some power he can drive it. It doesnt matter what he drives he can win wiyh any car. |
| Author: | ceej [ Sat Dec 27, 2008 7:17 pm ] |
You bought the Challenger Sergio? CJ |
| Author: | wayne erickson [ Sun Dec 28, 2008 6:30 am ] |
I don't think you will save that much weight going to the 8.8 vs. the 8 3/4" You might want to go to the 8" but then, don't have much choice with gearing options. The 8 3/4 really gives you much more options and you can always take off some #'s with the mini spool and lightweight yokes, ect. Just getting rid of the heavy disc both front and back and going to the Wildwood drilled lightwts will do the trick. Easy to bolt on...I could even do it....Lightweight alum. driveline should also help...Let me know when you have time for lunch...here or there.. Great project...Will it ever run as fast as a 170????? Later, Wayne |
| Author: | sergio [ Sun Dec 28, 2008 7:59 am ] |
Hi,Ceej no i dont need it.I have not seen it in person but it would cost a lot more than the asking price to build one like that. Hey Wayne lunch next week sounds good. I dont know if it will outrun a 170,but there will be plenty of room for a big turbo (oops ,that a secret too). |
| Author: | Ron Parker [ Sun Dec 28, 2008 8:29 am ] |
Guys this car has an alluninum 8 3/4 front housing already. Thanks Ron Parker It Aint Over Until I Win |
| Author: | Big T [ Tue Apr 14, 2009 5:00 pm ] |
I plan on picking up the 64 Dart from Sergio this weekend.. Have a spare motor and 904 trans set aside for the build... over the next year. Hope to have it completed enough to run it by October Redding race... Most diffently by MATS next year... Will be looking for a 8 3/4 rearend.... terry |
| Author: | madmax/6 [ Mon May 11, 2009 7:16 pm ] |
just weighed the Guzzi car today,came in at 2340 with full exhaust,in race trim with 30lbs of exhaust removed,I will be at 2310,trying to figure out where to get the last 10lbs out of it,dont want to remove carpet,I drive this car every day.Think I will start drilling out mt 80lbs sub frame connectors,I went way too heavy on them,Mark |
| Author: | ceej [ Tue May 12, 2009 8:10 am ] |
80#? Holy Long Beach Bat Man! Mine are tanks, but they don't weigh that much! How are you planning to drill them? CJ |
| Page 3 of 4 | All times are UTC-07:00 |
