It is currently Fri Nov 20, 2026 4:09 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Sep 18, 2009 8:35 pm
Its looking *much* better. The pattern is not quite centered yet, so the shim thickness still needs to be reduced. You probably noticed that the pattern didn't move that much with relatively large shim adjustments. Try removing another 0.010" or so, and keep the backlash at 0.006".
I'll be travelling on business for the next 1.5 weeks, so I won't be able to reply as quickly.
Ken
PostPosted: Sat Sep 19, 2009 5:20 am
Another .010 and I'll be right back where I started. :lol:
I've been tinkering with this for a couple months now so a week or two won't make much difference. I really appreciate your help.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Latest Effort
PostPosted: Wed Sep 23, 2009 4:29 pm
This first set of patterns is at .030 shim with .006 backlash. As I suspected, the pattern is heavy to the heel and high on the tooth.
Coast:
Drive:
Next I increased the Shim to .036 and .007 backlash. The drive side pattern is pretty much centered but the coast side is still to far outboard on the tooth.
Coast:
Drive:
Finally I reduced the shim to .033 and .008 backlash.
Coast:
Drive:
So, that's where it sits right now.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Sep 23, 2009 9:12 pm
It is unusual to get a perfect pattern on both sides of the tooth so focus on getting the drive side centered... which you have done.
I would run it and see how it sounds.
PostPosted: Thu Sep 24, 2009 4:40 am
Thanks Doc. That was pretty much what I was thinking too; I appreciate the confirmation. I'll do the final assembly this week and try to get it under the car. I still need to get some axle bearings and seals so I will probably order those today.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Sep 24, 2009 7:40 pm
Looks good. Preload the bearings and check to make sure the backlash remains toward the lower end of the allowable range. That's so that you have wiggle room should you ever remove the differential. The gears wear with a small step on the ring gear teeth, and each reinstallation requires slightly more backlash to assure that the edge of the pinion is not riding on the step.
Ken
PostPosted: Thu Sep 24, 2009 7:47 pm
Thanks again for all the help. It was a long process but I feel like I've learned some things.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Oct 09, 2009 6:23 pm
I did the final assembly this afternoon. I set the pinion preload to 25 in-lb, set the backlash to .007, snugged up the adjusters to get some preload on the carrier bearings and torqued down the caps. When I rechecked the pattern it was virtually perfect. Now to install the backing plates and axles and assemble the brakes and I will be ready to put it in the car. Thanks again to everyone who offered advice and encouragement, especially RustyRamcharger. I couldn't have done it without you.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Oct 09, 2009 7:59 pm
Did you remember to use blue Loctite on the ring gear screws? You can remove them one at a time to add Loctite, then retorque if you didn't. I had the factory-tightened screws (with no Loctite) on my Ramcharger Dana 44 front axle loosen and destroy the ring, pinion, differential case and bearings. A drop of Loctite is inexpensive insurance!
Ken
PostPosted: Fri Oct 09, 2009 8:34 pm
Actually I didn't and I'm glad you mentioned it. I did put red loctite ( supplied in the installation kit ) on the pinion nut. I'll get some blue and do that to the ring gear bolts.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Oct 09, 2009 10:00 pm
Blue is fine for most applications. Red requires heat (~400F iirc) to release. If you use red, use it sparingly. To make Loctite and its clones rapidly cure, use the aerosol primer. It is copper ions from the metal and/or the primer that triggers the chemical reaction.
Ken
PostPosted: Sat Oct 10, 2009 7:00 am
Congrats on the rear end. I think that etting up a rear end is harder then rebuilding an engine. I did my first one last winter with motive gears and I am anxiously waiting until my car is drivable to see how it goes down the road. Good work
Joe
1964 barracuda 198 slant
PostPosted: Sat Oct 10, 2009 9:34 am
Thanks Joe! I'm hoping and planning to have this one road-worthy if not finished, in time for Mopars at the Strip in March.
I can't say that it was hard to do, but it was definitely tedious and repititious. Once I got the hang of it I could take it apart, change the shims and put it back together in less than 1/2 hour. The place where I was holding my breath was final assembly and checking the mesh pattern after everything was torqued to spec. I didn't know if or how it would change when I took the setup bearing off and pressd on the actual bearing that I would be running. It was dead on so I'm very happy.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Oct 10, 2009 6:45 pm
Just a final comment to the last set of photos. Notice that there was a relatively large shift in the contact pattern between the 0.030", 0.033" and 0.036" shim thickness. That total shim thickness change is about the thickness of two sheets of paper, just to get a feel for the numbers. This sensitivity to the shim thickness is typical when the gears are properly meshed.
The photos from several weeks ago demonstrate that a large shim change (0.015-0.020") caused a small change in the contact pattern, typical of gears that are NOT properly meshed.
Always try to set up new gears with minimal backlash, so long as the contact pattern is satisfactory. Once the ring teeth wear, there will be a step in the drive face where the edge of the pinion tooth contacts. Should you have to remove and reinstall the gearset, measure the backlash before removal and reinstall it with ~0.002" additional backlash. This guarantees that the edge of the pinion tooth will not be riding against or on top of the wear step.
I'd say that this is a job well done! Without the factory set-up gages, one must resort to marking compound, but the end result will be the same if you are patient and pay attention to the details.
Ken
PostPosted: Sat Oct 10, 2009 7:52 pm
Once again, thank you for your advice, encouragment and patience. I couldn't have done it without you.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
