| Argentinean Slant Six "ACTC" Race Head https://slantsix.org/forum/viewtopic.php?t=37856 |
Page 3 of 3 |
| Author: | Polara1974 [ Thu Nov 12, 2009 7:25 am ] |
Radarsonwheels: Sounds like straight cut gears in the jeep, which I can't afford either! yes, and you also can hear in the video how the gear box literally BLOWS!!! I have found out that the company that casted this heads is in Tandil city, I tried to call but didn't get any answer. I'll be at that city on january for holidays, So I will spend some time there to see what happens ... Still can't find a a in car video of a Slant powered ACTC Dodge car ... damm |
| Author: | Volare4life [ Sun Nov 15, 2009 4:34 pm ] |
weren't the old muncie manual trannys straight cut gears ? What makes straight cut gears so great ? ( I must be showing my youg age here) -Mike |
| Author: | Joshie225 [ Sun Nov 15, 2009 5:30 pm ] |
Muncie transmissions have helical cut gears. They were just a better trans than the Saginaw units. Straight cut gears are quite loud. http://en.wikipedia.org/wiki/Gear |
| Author: | Volare4life [ Tue Nov 17, 2009 6:05 pm ] |
Thanks joshie didn't know, but is there any advantage to having straight cut gears over helical cut gears ? -Mike |
| Author: | Thropar [ Wed Nov 18, 2009 7:10 am ] |
Hey Mike, straight cut gears are stronger, but promote the old "if you can't find 'em - grind 'em" syndrome and other situations like double clutching to shift. I think the 4wd crowd likes them for pulling out tree stumps and boulders. On the cylinder head, I am looking forward to seeing more about this ACTC casting, where they can be obtained or if casting molds are sitting in a warehouse somewhere! |
| Author: | Dart270 [ Wed Nov 18, 2009 7:23 am ] |
Straight cut are also much easier to shift without using the clutch - good for road racing and other venues. Lou |
| Page 3 of 3 | All times are UTC-07:00 |
